MMM-ip
19 Posts 9 Posters 13.6k Views 8 Watching
    A module to show MagicMirror’s IPv4 Network Address
    [card:fewieden/MMM-ip]
    @PointPubMedia @amanzimdwini
    A P 3 Replies Last reply Jul 26, 2016, 2:36 PM Reply Quote 2
      PointPubMedia
      Thanks Strawberry!
      I just installed it, works fine.
      Except, I can’t really place it at the real bottom right… 'cause I’m using bottom_bar , bottom_right is just on top of bottom_bar
      S 1 Reply Last reply Jul 26, 2016, 1:54 PM Reply Quote 1
        strawberry 3.141 Project Sponsor Module Developer @PointPubMedia
        @PointPubMedia in your case you can take this config
        	module: 'MMM-ip',
        	position: 'bottom_bar'
        combined with
        div.MMM-ip div.module-content {
        	text-align: right;
        in ~/MagicMirror/css/custom.css
          amanzimdwini @strawberry 3.141
          @strawberry-3.141
          PERFECT
            @strawberry-3.141
            Did you read this?
            https://forum.magicmirror.builders/topic/408/serverstatus-from-ip-list-up-or-down
              Phate @strawberry 3.141
              @strawberry-3.141
              Works perfectly…
              • K Offline
                KirAsh4 Moderator
                Small note which probably doesn’t apply to the majority here … if anyone at all … other than me that is: my secondary rpi runs IPv6 exclusively (it’s a test platform), so your module would not work as it is specifically looking for the IPv4 field.
                Just something to think about …
                • K Offline
                  KirAsh4 Moderator
                  Expanding on what I said above, it might be easier to have the module report both IPv4 and IPv6, then have config options to turn them off:
                      displayIPv4: true,
                      displayIPv6: false,
                  S 1 Reply Last reply Jul 29, 2016, 2:26 PM Reply Quote 0
                    strawberry 3.141 Project Sponsor Module Developer @KirAsh4
                    @KirAsh4 done
                      based on @shashank’s request there is a new version, where you can define which network interface (wireless, ethernet or both) you want to display
                      WARNING: one config attribute changed it’s name for those who update
                      S 1 Reply Last reply Sep 18, 2016, 2:43 PM Reply Quote 0
