    Module(s) causing MagicMirror to lock up?
    6 Posts 3 Posters 2.8k Views 3 Watching
    • brandongomezB
      brandongomez
      Hi all. Newbie here and have built a MagicMirror with some really cool modules. However, I believe one or more of them is causing the mirror to lock up after around 4-5 hours. Is there a log where I can see where it might be happening?
      I have the following modules installed:
      default clock
      default calendar
      MMM-Instagram
      MMM-MyCommute
      MMM-pihole-stats
      MMM-ping
      MMM-Sonos
      MMM-WunderGround
      netatmo
      iFrame
      At first I thought it was something wrong with my Raspberry Pi 3 but that’s not the case. Then I thought turning off the display, coming back later and turning it on again was causing the Pi to halt or sleep, something like that but that doesn’t seem to be the case either. When I run my modified config.js file, it will run for around 4-5 hours and then the screen will freeze. I will be able to ping the IP but will not be able to ssh into it.
      I have put the sample config.js file back on and it’s been running with no issues so I can only guess that a module is causing it to eventually lock up. Maybe something with API calls? Or is there a max number of modules you can have?
      Really appreciate any help anyone can give. Thanks!
      • C
        Chiumanfu
        Comment out all the third party modules in the config.js then add them back one by one testing each. For me it was the iFrame module displaying an IP camera stream that locked up my pi.
        • brandongomezB
          brandongomez
          Thanks for the tip! Interesting. I have two iFrame modules displaying and I thought that was the one module that wouldn’t be causing an issue.
          • C
            Chiumanfu @brandongomez
            @brandongomez I think in my case, it was a bad IP Camera stream rather than a bad module.
            • brandongomezB
              brandongomez
              After removing some of the modules, it looks like my Pi-hole stats module was causing the problem. MagicMirror has been running fine for 24 hrs with that module commented out.
              • qu1queQ
                qu1que Project Sponsor
                I have the same problem with pi-hole-stats module. I’ve installed it on a raspberry pi zero mirror and on another raspberry pi3B mirror. And in both cases, the same problem. The screen turns black after a few hours working. The solution was the same: comment out the pi-hole-stats module. I don’t know why this happens
