    Facial recognition: no users
    9 Posts 2 Posters 4.9k Views 2 Watching
      mc_landin
      I am an absolute nooby when it comes to Raspberry’s and programming. I’m trying to get the facial recognition to work. However, I can’t get step 5 from the training model: “Copy down the [‘name’, ‘name2’,‘name3’] part because you will later need it for setting up your mirror’s face recognition and to test your face recognition model.” to work.
      A training file is generated, but there is no names part in the document? When I use the test tool the faces are recognised, however.
        mc_landin
        No-one able to help me out? :)
          j.e.f.f Project Sponsor Module Developer @mc_landin
          @mc_landin you need to specify the list of users in the same order as the training model outputs in your config for MMM-FacialRecognition.
          example:
                module: "MMM-Facial-Recognition",
                  recognitionAlgorithm: 1,
                  lbphThreshold: 50,
                  fisherThreshold: 250,
                  eigenThreshold: 3000,
                  useUSBCam: false,
                  trainingFile: "modules/MMM-Facial-Recognition-Tools/training.xml",
                  interval: 1,
                  logoutDelay: 15,
                  users: [‘name’,‘name2’,‘name3’],  /* put the list of users here. Order MUST be the same */
                  defaultClass: "default",
                  everyoneClass: "everyone",
                  welcomeMessage: false,
                  useProfileSwitcher: true
            mc_landin
            @j.e.f.f said in Facial recognition: no users:
            your
            Hi @j-e-f-f, thanks for the comment. my training model output does not seem to indicate any users?
              @mc_landin ah sorry I don’t know why that is then.
                mc_landin
                Anyone, please?
                  mc_landin
                  I am now a little further. It recognises me when I use the test tool, and when I am actually running the mirror, modules containing the class of my name are hidden. However, they do not actually become visible even when I am in front of the mirror?
                    mc_landin
                    Here is my code:
                       recognitionAlgorithm:1,
                       lbphTreshold: 80,
                       useUSBCam: false,
                       trainingfile: 'modules/MMM-Facial-Recognition/Training.xml',
                       interval: 2,
                       logoutDelay: 15,
                       users: ['Sander'],
                       defaultclass: "default",
                       welcomeMessage: true
                    PM2 logs mm specifies there is an issue, but doesn’t state what
                      mc_landin
                      Forgot to add the errors:
                      0|mm       |     model.load(config.get("trainingFile"))
                      0|mm       | cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/contrib/src/facerec.cpp:325: error: (-2) File can't be opened for writing! in function load
                      0|mm       |
                      0|mm       |
                      0|mm       |     at PythonShell.parseError (/home/pi/MagicMirror/modules/node_modules/python-shell/index.js:190:17)
                      0|mm       |     at terminateIfNeeded (/home/pi/MagicMirror/modules/node_modules/python-shell/index.js:98:28)
                      0|mm       |     at ChildProcess. (/home/pi/MagicMirror/modules/node_modules/python-shell/index.js:88:9)
                      0|mm       |     at emitTwo (events.js:106:13)
                      0|mm       |     at ChildProcess.emit (events.js:191:7)
                      0|mm       |     at Process.ChildProcess._handle.onexit (internal/child_process.js:215:12)
                      0|mm       |   executable: 'python',
                      0|mm       |   options: null,
                      0|mm       |   script: 'modules/MMM-Facial-Recognition/facerecognition/facerecognition.py',
                      0|mm       |   args: [ '{"recognitionAlgorithm":1,"lbphThreshold":80,"fisherThreshold":250,"eigenThreshold":3000,"useUSBCam":false,"trainingFile":"modules/MMM-Facial-Recognition/Training.xml","interval":2,"logoutDelay":15,"users":["Sander"],"defaultClass":"default","everyoneClass":"everyone","welcomeMessage":true}' ],
                      0|mm       |   exitCode: 1 }
