    Error after update..
    5 Posts 2 Posters 2.5k Views 2 Watching
    • C Offline
      campos
      Hello. Yesterday installed the script. It worked immediately. Then I played something and tried - and then deleted. Today I wanted to reinstall it, but now get the following error
      pi@raspberrypi-Kueche:~ $ npm start
      npm ERR! Linux 4.9.28-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.11.0
      npm ERR! npm  v3.10.10
      npm ERR! path /home/pi/package.json
      npm ERR! code ENOENT
      npm ERR! errno -2
      npm ERR! syscall open
      npm ERR! enoent ENOENT: no such file or directory, open '/home/pi/package.json'
      npm ERR! enoent This is most likely not a problem with npm itself
      npm ERR! enoent and is related to npm not being able to find a file.
      npm ERR! enoent
      npm ERR!     /home/pi/npm-debug.log
      Can someone help me or give a tip - would be super. greetings
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @campos
        @campos you are in the wrong directory. do cd MagicMirror first
        • C Offline
          campos
          Yes. But the same …pi@raspberrypi-Kueche:~ $ cd MagicMirror
          pi@raspberrypi-Kueche:~/MagicMirror $ npm start
          magicmirror@2.1.2 start /home/pi/MagicMirror
          sh run-start.sh
          /home/pi/MagicMirror/node_modules/electron/index.js:9
          throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’)
          Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
          at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions…js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.require (module.js:497:17)
          at require (internal/module.js:20:19)
          at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
          npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
          npm ERR! code ELIFECYCLE
          npm ERR! magicmirror@2.1.2 start: sh run-start.sh
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the magicmirror@2.1.2 start script ‘sh run-start.sh’.
          npm ERR! If you do, this is most likely a problem with the magicmirror package,
          npm ERR! not with npm itself.
          npm ERR! sh run-start.sh
          npm ERR! npm bugs magicmirror
          npm ERR! Or if that isn’t available, you can get their info via:
          npm ERR! npm owner ls magicmirror
          npm ERR! /home/pi/MagicMirror/npm-debug.log
            @campos
            • C Offline
              campos
              Ah. I got it after a long time back and forth. Once again deleted and the folder copied again. Many thanks for your help.
