    MMM-uber and MMM-lyft
    40 Posts 8 Posters 36.3k Views 7 Watching
      Sarb @kal
      @kal Please see my config entries below:
      		module: 'MMM-uber',
      		position: 'top_right',
      		header: 'Uber & Lyft',
      			lat: <>,
      			lng: <>,
      			uberServerToken: '<>',
      		module: 'MMM-uber',
      			lat: <>,
      			lng: <>,
      			ride_type: 'uberXL',
      		module: 'MMM-lyft',
      			lat: <>,
      			lng: <>,
      			clientID: '<>',
      			clientSecret: '<>',
      Sorry for being such a noob but I am not sure where to pull my log file from. I ran a quick search and I read that it is supposed to be in a folder named pm2 in my pi folder but I do not see a folder with that name (even when showing hidden items). I did however notice this in my console window:
      Whoops! There was an uncaught exception…
      TypeError: Cannot read property ‘statusCode’ of undefined
      at Request._callback (/home/pi/MagicMirror/modules/MMM-lyft/node_helper.js:43:97)
      at self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
      at emitOne (events.js:96:13)
      at Request.emit (events.js:191:7)
      at Auth.basic (/home/pi/MagicMirror/node_modules/request/lib/auth.js:24:18)
      at Auth.onRequest (/home/pi/MagicMirror/node_modules/request/lib/auth.js:137:23)
      at Request.auth (/home/pi/MagicMirror/node_modules/request/request.js:1360:14)
      at Request.init (/home/pi/MagicMirror/node_modules/request/request.js:378:10)
      at new Request (/home/pi/MagicMirror/node_modules/request/request.js:130:8)
      at request (/home/pi/MagicMirror/node_modules/request/index.js:54:10)
      kalK 1 Reply Last reply
      • kalK
        kal @Sarb
        @Sarb your config looks good, but I want to see your log before I open an issue.
        We need to view your JavaScript console. Access the mirror directly or whitelist the IP of another computer to access via a browser. Then, go to https://IP.of.Raspberry.Pi:8080 in Chrome and View>Developer>JavaScript Console.
        See this this thread for more info.
          Sarb @kal
          @kal Please see below:
          Filtering for Uber
          Filtering for Lyft
          • kalK
            kal @Sarb
            @Sarb Two things:
            1. Make sure that your uberServerToken and clientID/clientSecret don’t contain the greater/less than characters in your config (these things: <>). Those are placeholders. For example, if your uberServerToken is abc123 then the line in your config should read uberServerToken: 'abc123', without those characters.
            2. If that doesn’t work, can you go into the .js file for uber and un-comment this line. Then post the log. You should be looking for one that says ERROR...
              Sarb @kal
              @kal
              1. I can confirm my uberServerToken and clientID/clientSecret don’t contain the greater/less than characters in my config file. I only used those so I wasn’t displaying them. :)
              2. Please see screenshot below:
              • kalK
                kal @Sarb
                @Sarb from the docs it looks like you supplied an invalid code. Can you regenerate your token and try again?
                Also, what country are you in?
                  Sarb @kal
                  @kal Looks like regenerating the uber server token did the trick! Not sure how it could have been invalid the first time since I copy and pasted it. Thank you very much for your help, however I am still seeing the same issue with the Lyft module. I refreshed my Client Secret and copied the new string, but it did not fix anything. I also commented out the same line in the lyft js file. Screenshot below, I do not see any errors. I am located in Southern California if that helps.
                  • kalK
                    kal @Sarb
                    @Sarb Are you sure you uncommented / that’s all of the Lyft outputs? There should be more.
                      Sarb @kal
                      @kal I can confirm that I uncommented line 143 of the MMM-Lyft.js file. Could the issue possibly be tied to the error I sent earlier that I see in my console window? Copying once more so it is easier to find.
                      • kalK
                        kal @Sarb
                        @Sarb you’re encountering an access error and that exception is a symptom, not a cause. My advice would be to regenerate Lyft ID and Secret for your config or perhaps register as a new user and get a new ID.
                          Sarb @kal
                          @kal Thank you for all your help. After a bunch of troubleshooting I was finally able to notice that I was using “clientID” instead of “clientId” in my config file. It is working now.
                          • kalK
                            kal @Sarb
                            @Sarb yea that was a confusing thing for me to do (I’ll consider changing in the next version). In the future make sure to just copy and paste from the GitHub page.
                            Glad you’re all sorted out!
                            • twosquirrelsT
                              twosquirrels
                              My MMM-uber has been fine for weeks, but just says “uberX in undefined min” for the last couple of days. Anybody else have this issue?
                              J 1 Reply Last reply
                              • J
                                jdahli1 @twosquirrels
                                @twosquirrels I’m having the same issue as you. An issue with the Uber API perhaps?
                                twosquirrelsT 1 Reply Last reply
                                • twosquirrelsT
                                  twosquirrels @jdahli1
                                  @jdahli1 I tried deleting my uber api key and generating a brand new key and it didn’t help. I reinstalled my magicmirror from scratch and it didn’t help. The API must have changed.
                                  • twosquirrelsT
                                    twosquirrels
                                    I completely deleted the uber module folder and reinstalled. That fixed it. I could have sworn I tried that, but it worked just now.
                                    • twosquirrelsT
                                      twosquirrels
                                      I now get this bizarre issue where Lyft shows the times in minutes down to 15 decimal places. Anybody else?
                                      • F
                                        futurahem
                                        Hi all. Is this still working?
                                        I installed the module as directed and added the module to config. I moved some stuff around to confirm it was actually affecting the mirror but the Uber module doesn’t appear no matter that I do.
                                        In the past when I had an error the place holder would pop up but It’s loading just fine just not this module (Uber in particular).
                                        • F
                                          futurahem
                                          Right after posting I figured it out. When you download/clone the git it has a -master at the end. In the config the module name is “mmm-uber” and as that wasn’t matching up to the folder in the modules folder (in case anyone else experiences this) it wasn’t coming up.
                                          • M
                                            menanr
                                            does the Uber and Lyft modules still work?
