    Blackscreen
    7 Posts 3 Posters 3.0k Views 3 Watching
    • DocVooDooD Offline
      DocVooDoo
      Hello people I have the following problem as one can recognize. It was suddenly there. What can I do?
      pi@magicmirror:~/MagicMirror $ node serveronly
      Starting MagicMirror: v2.1.2
      Loading config ...
      Loading module helpers ...
      Module helper loaded: MMM-Remote-Control
      Module helper loaded: MMM-WatchDog
      Module helper loaded: MMM-SystemStats
      No helper found for module: MMM-Scrobbler.
      Module helper loaded: MMM-FRITZ-Box-Callmonitor
      No helper found for module: MMM-Callmonitor-Current-Call.
      Module helper loaded: MMM-NetworkScanner
      Module helper loaded: MMM-WunderGround
      Module helper loaded: MMM-DWD-WarnWeather
      Module helper loaded: MMM-teamspeak3
      No helper found for module: MMM-doomsDay.
      Module helper loaded: MMM-Fuel
      Module helper loaded: MMM-Volumio
      No helper found for module: MMM-AlarmClock.
      Module helper loaded: MMM-MyCommute
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-Remote-Control
      Starting node helper for: MMM-Remote-Control
      Connecting socket for: MMM-WatchDog
      Starting module helper: MMM-WatchDog
      Connecting socket for: MMM-SystemStats
      Connecting socket for: MMM-FRITZ-Box-Callmonitor
      Starting module: MMM-FRITZ-Box-Callmonitor
      Connecting socket for: MMM-NetworkScanner
      Starting module: MMM-NetworkScanner
      Connecting socket for: MMM-WunderGround
      MMM-WunderGround helper started ...
      Connecting socket for: MMM-DWD-WarnWeather
      MMM-DWD-WarnWeather helper started...
      Connecting socket for: MMM-teamspeak3
      Connecting socket for: MMM-Fuel
      Starting module helper: MMM-Fuel
      Connecting socket for: MMM-Volumio
      --- MMM-Volumio: Node Helper Start
      Starting module: newsfeed
      Connecting socket for: MMM-MyCommute
      ====================== Starting node_helper for module [MMM-MyCommute]
      Ready to go! Please point your browser to: http://localhost:8080
      ERROR! Could not find main module js file.
        DocVooDoo
        > magicmirror@2.1.2 start /home/pi/MagicMirror
        > sh run-start.sh
        Loading config ...
        Server started ...
        Launching application.
        Access denied to IP address: 192.168.178.31
        MMM-NetworkScanner received SCAN_NETWORK
        MMM-NetworkScanner is performing arp-scan
          j.e.f.f Project Sponsor Module Developer
          The only error I see is that MagicMirror can’t find the module.js file. This file is normally in the MagicMirror/js/ directory. Verify that the file is actually there. If it’s not (I have not clue how it might have been deleted) maybe try running git pull from the MagicMirror root directory to see see if it refreshes the file. You can also try git checkout js/module.js
          your MagicMirror/js/ directory should contain all the files you see here:
          https://github.com/MichMich/MagicMirror/tree/master/js
          I hope this helps.
            DocVooDoo
            i have the mm2 new installed and the problem…
            Access denied to IP address: 192.168.178.58
            The Monitor is Black after starting
            • strawberry 3.141S Offline
              strawberry 3.141 Project Sponsor Module Developer @DocVooDoo
              @DocVooDoo then you should check your whitelist setting
                DocVooDoo
                the IP 192.168.178.58 ist from the Mirror RPi…
                  DocVooDoo
                  i have completly new installed Raspbian and MagicMirror. The Modules are also reinstalled. The Problem with the IP is gone. Why ever…
