Navigation
    • Search
    Where to begin for module making?
    Development
    • T
      Terrence last edited by
      Good Morning All.
      I have recently started with MagicMirror, set up a few things… edited a couple of modules, just having fun with it you know.
      Now I would like to make my own module as what I want doesn’t exist.
      Firstly my question then I will explain what the module must do…
      So where would one start to make a module and in what language would you code?
      Now what must it do you ask?
      Well…
      Play music.
      But I would like it to have a “play this folder” option and to be controlled by an apple remote (which is already setup).
      So basically I will have a few folders which will work as playlists.
      Thank you so much for any help that you can provide.
      strawberry 3.141 1 Reply Last reply Reply Quote 0
      • strawberry 3.141
        strawberry 3.141 Project Sponsor Module Developer @Terrence last edited by
        @Terrence you’re probably interested in this https://forum.magicmirror.builders/topic/4232/so-then-what-languages-to-learn
        and https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
        • T
          That is perfect. Thank you very much strawberry!
          • SvenSommer
            SvenSommer last edited by
            I can highly recommend to use the MagicMirror-Module-Template. It has already build in some of the most common features modules need.
            There samples of code for:
            • External request
            • Config parameters
            • Custom URL path route
            • Passing of messages (NOTIFICATIONS)
            In addition it’s builds the framework for your module by running a script.
            • T
              Excellent. Thank you SvenSommer. I will definitely use that to help.
              I love your build. Very stunning!
