    Change Fontsize
    9 Posts 5 Posters 20.0k Views 6 Watching
      reaper81
      Hello everyone,
      can I change the fontsize in general? I have a lot of modules but not enougth space on the screen. Thanks a lot.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @reaper81
        @reaper81 yes you can
        .xsmall {
          font-size: 15px;
          line-height: 20px;
        .small {
          font-size: 20px;
          line-height: 25px;
        .medium {
          font-size: 30px;
          line-height: 35px;
        .large {
          font-size: 65px;
          line-height: 65px;
        .xlarge {
          font-size: 75px;
          line-height: 75px;
          letter-spacing: -3px;
        put that in your custom.css file, change the numbers to your liking and you will cover most of the modules which uses those css classes
        or what @j-e-f-f suggested in the other thread https://forum.magicmirror.builders/post/25506 to scale everything in the same portion
          reaper81
          thanks, i will try it. strange that nobody asked this before.
            anustart
            This post is deleted!
              anustart
              Do I need to past all of the above in CSS file?
              Is this redefine what the preset fonts already are?
                j.e.f.f Project Sponsor Module Developer @anustart
                @anustart if you simply paste the above you’ll have no change, as I believe these are the defaults for these classes. Modify the values for font-size and line-height to your liking. You may also want to add letter-spacing properties to decrease space between letters in order to fit more on one line. Example:
                .medium {
                  font-size: 26px;
                  line-height: 30px;
                  letter-spacing: -2px;
                If you really want to get your hands dirty, you may want to consider switching to a narrow font. (I believe RobotoCondensed is already included by default):
                .medium {
                  font-family: 'RobotoCondensed';
                  font-size: 26px;
                  line-height: 30px;
                  anustart @j.e.f.f
                  @j.e.f.f that work!
                  • ? Offline
                    A Former User
                    @j.e.f.f said in Change Fontsize:
                    RobotoCondensed
                    But that leads to a general question about the fonts :
                    RobotoCondensed is not in the fonts directory, they all have an addition, like RobotoCondensed-light, etc…
                    Does that matter ?
                    The main.css uses ‘Roboto Condensed’.
                    Again, is that difference important ?
                      j.e.f.f Project Sponsor Module Developer @Guest
                      @howi42 it just means that there are several weights available. When you use the font in your CSS, you can specify the weight as follows:
                      font-family: "Roboto Condensed";
                      font-weight: normal; /* bold, 300, 100, etc. */
