    Input...What do you think?
    54 Posts 9 Posters 46.8k Views 7 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @barnosch
      @barnosch said in Input...What do you think?:
      Looks very nice.
      The german translation seems to be wrong ;) and not even added to the MMM-NOAA.js
      Guess your are still in the middle of development.
      Added it myself but it is not working yet.
      Also i would like a 24hours setting, if possible.
      Thansk for your work
      PS: is this correct in the default settings? Guess not.
      show: "F".toLowerCase(), // show F or C Temps
      In your config.js file at the top…
          ```timeFormat: 12,  // change that to a 24 ;) ```
        Hot off the presses … Swedish translation :) Thanks again @Snille
        [If anyone would be kind enough to do the German translation I’d appreciate it!! PM me!]
        SnilleS P 3 Replies Last reply Reply Quote 1
          Looks very nice.
          Done… in the config file it’s
          format: "12" or "24"
          testing
            barnosch
            Thanks. I already fixed it at my mirror with
            (config was already in 24hours mode)
            changeing this line
            //  time = time.toLocaleString('en-US', { hour: 'numeric',minute:'numeric', hour12: true });
                   time = time.toLocaleString('de-DE', { hour: 'numeric',minute:'numeric', hour24: true });
            which did the job
            And for the sunset and sunrise i just changed to
            H:mm
            Ugly and hardcoded but worked for me. with my low programming skills.
            How is the correct way to update the repository via git? I’m kind of new to this stuff.
            cowboysdudeC 2 Replies Last reply Reply Quote 1
            • SnilleS Offline
              Snille Module Developer @cowboysdude
              @cowboysdude Ah, Thank you! Looking good. I’ll pull when I have some time. :)
              If you cant find it, make it and share it
              MMM-homeassistant-sensors,MMM-Modulebar,MMM-Profilepicture,MMM-Videoplayer,MMM-TautulliLatest
                changeing this line
                which did the job
                H:mm
                No you did great but I will put in a fix for it and you can do a git pull later :)
                Ok the fix is in… the time will automatically read your language in the config.js file and adjust itself accordingly… However you will want to keep your sunrise/sunset ‘fix’ for now because I did not change that. :)
                • P Offline
                  planet4 @cowboysdude
                  This post is deleted!
                  • P Offline
                    @cowboysdude Looking forward to this but it should be prognos and not prognås right? In the swedish translation.
                    SnilleS 1 Reply Last reply Reply Quote 0
                    • SnilleS Offline
                      Snille Module Developer @planet4
                      @planet4 “Prognås” is my bad… :) Sorry… You are correct. I thought it looked strange. :)
                        changeing this line
                        which did the job
                        H:mm
                        Ok so it’s all updated.
                        As I said above the time zone will adjust automatically and to show the AM/PM on the Sunrise/Sunset time is now a config option [See Readme on Github].
                        To update go to:
                        ~MagicMirror/modules/MMM-NOAA
                        type: git pull
                        That should update for you ;)
                        • SnilleS Offline
                          @cowboysdude Hmm… I’m thinking maybe you are working double here… There should be a “global” locale variable you can use. That’s set in the top of the config file. You should be able to use that one some how. I just don’t know how. :)
                            cowboysdude Module Developer @Snille
                            @Snille said in Input...What do you think?:
                            Not sure either :) So what I did was to use the ‘language’ and ‘format’ from the top of the config.js file because it was there … HAHA. So I took advantage of this:
                            language: 'en',
                            timeFormat: 12,
                            units: 'imperial'
                            If something comes to mind please feel free! Always looking for a better way :) Honestly I dislike making config options … too many is not a good thing I think.
                            • strawberry 3.141S Offline
                              strawberry 3.141 Project Sponsor Module Developer @cowboysdude
                              @cowboysdude you can access the global config by config.timeFormat instead of the local module config this.config.timeFormat
                              cowboysdudeC 1 Reply Last reply Reply Quote 2
                                cowboysdude Module Developer @strawberry 3.141
                                @strawberry-3.141 said in Input...What do you think?:
                                config.timeFormat
                                Thank you for that!!! One config option gone :) There now the time function is all automatic :) ALL controlled by the users input here:
                                    language: 'en',
                                    timeFormat: 12,
                                Ok I’ve had my tea and toast so I must head out the door for the day :)
                                • 3 / 3
