    Input...What do you think?
    54 Posts 9 Posters 48.0k Views 7 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @Snille
      @Snille
      “250,000+ personal weather stations across the globe already send data to Weather Underground!”
      Not a single one in Sweden, according to https://www.wunderground.com/weatherstation/ListStations.asp?selectedCountry=Sweden
      • cowboysdudeC
        @Mykle1 said in Input...What do you think?:
        @Snille
        That’s NO GOOD.
        Mykle1M 1 Reply Last reply
        • Mykle1M
          @cowboysdude
          @Snille’s next project? :-)
          • cowboysdudeC
            @Mykle1 OH wait don’t I have like 2 other weather modules I made and NEVER released? Perhaps I can salvage one of those… hummmmmmmmmmmmm
            • Mykle1M
              @cowboysdude
              We don’t want the other ones. We want this one!
              Make it work! :-)
              • cowboysdudeC
                Thanks to Mykle we’ve changed the api call and NOW it should cover just about the entire world … well if you have a pws close by you :)
                Thanks to @Snille and @Mykle1 for their help… like I said didn’t plan on releasing this and honestly only asking for what others thought of it but hey looks like once the bugs are all ironed out it’ll be coming to a mirror near you…
                  barnosch
                  Looks very nice.
                  The german translation seems to be wrong ;) and not even added to the MMM-NOAA.js
                  Guess your are still in the middle of development.
                  Added it myself but it is not working yet.
                  Also i would like a 24hours setting, if possible.
                  Thansk for your work
                  PS: is this correct in the default settings? Guess not.
                  show: "F".toLowerCase(), // show F or C Temps
                  Mykle1M cowboysdudeC 3 Replies Last reply
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @barnosch
                    @barnosch said in Input...What do you think?:
                    You don’t have to guess. All you have to do is actually read what he wrote in the post above yours. :-)
                    • cowboysdudeC
                      • cowboysdudeC
                        cowboysdude Module Developer @barnosch
                        Looks very nice.
                        In your config.js file at the top…
                            ```timeFormat: 12,  // change that to a 24 ;) ```
                        • cowboysdudeC
                          Hot off the presses … Swedish translation :) Thanks again @Snille
                          [If anyone would be kind enough to do the German translation I’d appreciate it!! PM me!]
                          SnilleS P 3 Replies Last reply
                          • cowboysdudeC
                            Looks very nice.
                            Done… in the config file it’s
                            format: "12" or "24"
                            testing
                              barnosch
                              Thanks. I already fixed it at my mirror with
                              (config was already in 24hours mode)
                              changeing this line
                              //  time = time.toLocaleString('en-US', { hour: 'numeric',minute:'numeric', hour12: true });
                                     time = time.toLocaleString('de-DE', { hour: 'numeric',minute:'numeric', hour24: true });
                              which did the job
                              And for the sunset and sunrise i just changed to
                              H:mm
                              Ugly and hardcoded but worked for me. with my low programming skills.
                              How is the correct way to update the repository via git? I’m kind of new to this stuff.
                              cowboysdudeC 2 Replies Last reply
                              • SnilleS
                                Snille Module Developer @cowboysdude
                                @cowboysdude Ah, Thank you! Looking good. I’ll pull when I have some time. :)
                                • cowboysdudeC
                                  changeing this line
                                  which did the job
                                  H:mm
                                  No you did great but I will put in a fix for it and you can do a git pull later :)
                                  Ok the fix is in… the time will automatically read your language in the config.js file and adjust itself accordingly… However you will want to keep your sunrise/sunset ‘fix’ for now because I did not change that. :)
                                    planet4 @cowboysdude
                                      @cowboysdude Looking forward to this but it should be prognos and not prognås right? In the swedish translation.
                                      SnilleS 1 Reply Last reply
                                      • SnilleS
                                        Snille Module Developer @planet4
                                        @planet4 “Prognås” is my bad… :) Sorry… You are correct. I thought it looked strange. :)
                                        • cowboysdudeC
                                          changeing this line
                                          which did the job
                                          H:mm
                                          Ok so it’s all updated.
                                          As I said above the time zone will adjust automatically and to show the AM/PM on the Sunrise/Sunset time is now a config option [See Readme on Github].
                                          To update go to:
                                          ~MagicMirror/modules/MMM-NOAA
                                          type: git pull
                                          That should update for you ;)
                                          • SnilleS
                                            @cowboysdude Hmm… I’m thinking maybe you are working double here… There should be a “global” locale variable you can use. That’s set in the top of the config file. You should be able to use that one some how. I just don’t know how. :)
                                            • 3 / 3
