    Input...What do you think?
    54 Posts 9 Posters 46.8k Views 7 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @Snille
      @Snille said in Input...What do you think?:
      @cowboysdude Hmm… I forgot a “comma” on the
      en: "translations/en.json"
      line… Sorry…
      should be:
      en: "translations/en.json",
      And then it seems to be missing something else…
      I get this error…
      Uncaught TypeError: Cannot read property 'simpleforecast' of undefined
          at Class.processNoaa (MMM-NOAA.js:58)
          at Class.socketNotificationReceived (MMM-NOAA.js:88)...
      But I have to go to bed… REALLY now… :)
      It doesn’t recognize your location :(
        Mykle1 Project Sponsor Module Developer @Snille
        @Snille
        “250,000+ personal weather stations across the globe already send data to Weather Underground!”
        Not a single one in Sweden, according to https://www.wunderground.com/weatherstation/ListStations.asp?selectedCountry=Sweden
          @Mykle1 said in Input...What do you think?:
          @Snille
          That’s NO GOOD.
            @cowboysdude
            @Snille’s next project? :-)
              @Mykle1 OH wait don’t I have like 2 other weather modules I made and NEVER released? Perhaps I can salvage one of those… hummmmmmmmmmmmm
                @cowboysdude
                We don’t want the other ones. We want this one!
                Make it work! :-)
                  Thanks to Mykle we’ve changed the api call and NOW it should cover just about the entire world … well if you have a pws close by you :)
                  Thanks to @Snille and @Mykle1 for their help… like I said didn’t plan on releasing this and honestly only asking for what others thought of it but hey looks like once the bugs are all ironed out it’ll be coming to a mirror near you…
                    barnosch
                    Looks very nice.
                    The german translation seems to be wrong ;) and not even added to the MMM-NOAA.js
                    Guess your are still in the middle of development.
                    Added it myself but it is not working yet.
                    Also i would like a 24hours setting, if possible.
                    Thansk for your work
                    PS: is this correct in the default settings? Guess not.
                    show: "F".toLowerCase(), // show F or C Temps
                    Mykle1M cowboysdudeC 3 Replies Last reply Reply Quote 0
                      Mykle1 Project Sponsor Module Developer @barnosch
                      @barnosch said in Input...What do you think?:
                      You don’t have to guess. All you have to do is actually read what he wrote in the post above yours. :-)
                          cowboysdude Module Developer @barnosch
                          Looks very nice.
                          In your config.js file at the top…
                              ```timeFormat: 12,  // change that to a 24 ;) ```
                            Hot off the presses … Swedish translation :) Thanks again @Snille
                            [If anyone would be kind enough to do the German translation I’d appreciate it!! PM me!]
                            SnilleS P 3 Replies Last reply Reply Quote 1
                              Looks very nice.
                              Done… in the config file it’s
                              format: "12" or "24"
                              testing
                                barnosch
                                Thanks. I already fixed it at my mirror with
                                (config was already in 24hours mode)
                                changeing this line
                                //  time = time.toLocaleString('en-US', { hour: 'numeric',minute:'numeric', hour12: true });
                                       time = time.toLocaleString('de-DE', { hour: 'numeric',minute:'numeric', hour24: true });
                                which did the job
                                And for the sunset and sunrise i just changed to
                                H:mm
                                Ugly and hardcoded but worked for me. with my low programming skills.
                                How is the correct way to update the repository via git? I’m kind of new to this stuff.
                                cowboysdudeC 2 Replies Last reply Reply Quote 1
                                • SnilleS Offline
                                  Snille Module Developer @cowboysdude
                                  @cowboysdude Ah, Thank you! Looking good. I’ll pull when I have some time. :)
                                    changeing this line
                                    which did the job
                                    H:mm
                                    No you did great but I will put in a fix for it and you can do a git pull later :)
                                    Ok the fix is in… the time will automatically read your language in the config.js file and adjust itself accordingly… However you will want to keep your sunrise/sunset ‘fix’ for now because I did not change that. :)
                                      planet4 @cowboysdude
                                        @cowboysdude Looking forward to this but it should be prognos and not prognås right? In the swedish translation.
                                        SnilleS 1 Reply Last reply Reply Quote 0
                                        • SnilleS Offline
                                          Snille Module Developer @planet4
                                          @planet4 “Prognås” is my bad… :) Sorry… You are correct. I thought it looked strange. :)
                                            changeing this line
                                            which did the job
                                            H:mm
                                            Ok so it’s all updated.
                                            As I said above the time zone will adjust automatically and to show the AM/PM on the Sunrise/Sunset time is now a config option [See Readme on Github].
                                            To update go to:
                                            ~MagicMirror/modules/MMM-NOAA
                                            type: git pull
                                            That should update for you ;)
                                            • 2 / 3
