    Final Step of Installing MagicMirror (EXTREME NOOB)
    4 Posts 2 Posters 1.5k Views 2 Watching
    • H Offline
      hall1458
      Hello,
      I followed the step-by-step instructions very closely (at least I thought), but I’m running into a problem at the very last step. I’m not familiar with working in the terminal, so I don’t really know what’s wrong even though I’m sure it’s a simple fix. The error code is below and the debug file is below that. Any help would be appreciated.
      //pi@raspberrypihall1458:~ $ cd MagicMirror/config
      pi@raspberrypihall1458:~/MagicMirror/config $ cp config.js.sample config.js
      pi@raspberrypihall1458:~/MagicMirror/config $ cd $HOME/MagicMirror
      pi@raspberrypihall1458:~/MagicMirror $ npm start
      > magicmirror@2.1.2 start /home/pi/MagicMirror
      > sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! Linux 4.9.39-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.11.1
      npm ERR! npm  v3.10.10
      npm ERR! file sh
      npm ERR! code ELIFECYCLE
      npm ERR! errno ENOENT
      npm ERR! syscall spawn
      npm ERR! magicmirror@2.1.2 start: `sh run-start.sh`
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.2 start script 'sh run-start.sh'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      ******* DEBUG FILE ********
      1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
      2 info using npm@3.10.10
      3 info using node@v6.11.1
      5 info lifecycle magicmirror@2.1.2~prestart: magicmirror@2.1.2
      6 silly lifecycle magicmirror@2.1.2~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.1.2~start: magicmirror@2.1.2
      8 verbose lifecycle magicmirror@2.1.2~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.1.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      10 verbose lifecycle magicmirror@2.1.2~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.1.2~start: Args: [ '-c', 'sh run-start.sh' ]
      12 info lifecycle magicmirror@2.1.2~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.1.2 start: `sh run-start.sh`
      13 verbose stack spawn ENOENT
      13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
      13 verbose stack     at emitTwo (events.js:106:13)
      13 verbose stack     at ChildProcess.emit (events.js:191:7)
      13 verbose stack     at maybeClose (internal/child_process.js:891:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      14 verbose pkgid magicmirror@2.1.2
      15 verbose cwd /home/pi/MagicMirror
      16 error Linux 4.9.39-v7+
      17 error argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      18 error node v6.11.1
      19 error npm  v3.10.10
      20 error file sh
      21 error code ELIFECYCLE
      22 error errno ENOENT
      23 error syscall spawn
      24 error magicmirror@2.1.2 start: `sh run-start.sh`
      24 error spawn ENOENT
      25 error Failed at the magicmirror@2.1.2 start script 'sh run-start.sh'.
      25 error Make sure you have the latest version of node.js and npm installed.
      25 error If you do, this is most likely a problem with the magicmirror package,
      25 error not with npm itself.
      25 error Tell the author that this fails on your system:
      25 error     sh run-start.sh
      25 error You can get information on how to open an issue for this project with:
      25 error     npm bugs magicmirror
      25 error Or if that isn't available, you can get their info via:
      25 error     npm owner ls magicmirror
      25 error There is likely additional logging output above.
      26 verbose exit [ 1, true ]
      Thanks!
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @hall1458
        @hall1458 did you install the dependencies with npm install?
        • H Offline
          hall1458
          No I don’t think so, and that must be my issue. I don’t see this in the complete setup instructions though. Where would I install the dependencies? Again, I’m very new to this so I’m probably missing it. Thanks for the help.
            @hall1458 cd ~/MagicMirror then npm install
