NASCAR standings
@dwlyles said in NASCAR standings:
@emlowe so thinking, may need to update once a year?
I’ll look at it later today … have to work
It would need to be in rotating format because a chart would just be too big for the mirror
Took a few minutes while having coffee and threw something together real quick… I have the data it seems to work so I’ll make it look pretty when I get home
@emlowe said in NASCAR standings:
I scraped that out of the nascar page. Seems promising but unclear if it will work long term.
Any chance you can scrape the NFL standings from
http://www.scoreboard.com/nfl/standings/or somewhere
@dwlyles is this what you’re looking for?
You’re a magician!
The NFL seems to use scoreboard.com which is much less obvious how to fetch their data. There are using some AJAX calls, but when I try to call them directly I get denied - there is likely some cookie involved. I suspect it would be somewhat complicated to fetch.
-Earle
@cowboysdude this is amazing! you definitely are a magician!!
