    MMM-CalendarExt
    198 Posts 45 Posters 231.4k Views 45 Watching
      redink
      I just updated this module, and it stopped working. I even tried resting to the simple config from the readme, and nothing is coming up. Where can I see the logs for it to try and fix this?
      • ? Offline
        A Former User @redink
        @redink
        stop pm2 mm then npm start dev in your MM directory root.
        • V Offline
          Vauxdvihl
          @Sean
          Sorry to ask again
          Is there any possibility to increase a little bit the size of the letters?
          I mean the ones showing in the calendar as a “task”?
          thanks
          • ? Offline
            A Former User @Vauxdvihl
            @vauxdvihl
            You can adjust anything in CSS. (It could not be so easy but really funny)
            Or tell me which letters to be increased.
            • V Offline
              Vauxdvihl
              @Sean
              I want to play around with the following values
              Increase / Decrease “FINAL: SEA7 - OAK 6”
              Increase / Decrease “Time (04:05-07:05)”
              I am not a programmer :-)
              Thanks a lot
              • ? Offline
                @vauxdvihl
                Add this into your MagicMirror/css/custom.css file.
                .CALEXT .eventTime {
                  font-size: 120%;
                  line-height:110%;
                .CALEXT .eventContent {
                  font-size: 140%;
                  line-height:110%;
                You can adjust these values with relative % or absolute px (Or many other various things)
                https://www.w3schools.com/cssref/pr_font_font-size.asp
                • V Offline
                  Vauxdvihl
                  @Sean
                  Thanks a lot
                  In custom css file a have the following:
                  div.CALEXT  .event .symbol {
                      order:1;
                      display:block;
                      flex-basis: 30px; // Modify this
                      text-align:center;
                      min-width: 50px; // Modify this
                      font-size: 150%; // Add this
                  div.CALEXT .events .symbol.emoji {
                      font-size: 150%; //Adjust this as your wish. you can use px or %
                  div.CALEXT .events .symbol.font-awesome {
                      font-size: 250%; //Adjust this as your wish. you can use px or %
                  div.CALEXT .tableStyle .eventTime {
                      display:block;
                    font-size: 80%;
                    line-height:110%;
                    font-size: 250%;
                    line-height:110%;
                  The adjustment of time works fine.
                  But not of the initial content.
                  Sorry
                  But can you please help again
                  Thanks a lot
                  • ? Offline
                    @vauxdvihl
                    Because your other CSS rules might override that rule. (Simpler rule name might have lower priority). See this. https://developer.mozilla.org/en-US/docs/Web/CSS/Specificity
                    Anyway, you can use like this;
                     div.CALEXT div.slot div.eventsBoard div.eventContainer div.eventContent {
                       font-size: 250%;
                       line-height:110%;
                    (For more exact rule specificity, I should know whole CSS of your MM, but I believe above code enough)
                    • Y Offline
                      yoey2112
                      Hello @Sean ,
                      Been playing around with this module for a day now (not very savvy with javascript) and I cannot figure out how to increase the size of my Calendar. I’m using weeks (4 count) and position bottom_bar, but I would like it to take up about a third of the bottom (vertical monitor). I know this must be a change in CSS, but I dont know what to do. Any help would be great!
                      -Yoey
                      • ? Offline
                        A Former User @yoey2112
                        @yoey2112
                        Which parts do you want to grow up? More details I need to help. Image could be a help.
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 19
                        • 20
                        • 11 / 20
