    MMM-CalendarExt
    198 Posts 45 Posters 231.4k Views 45 Watching
    • Y Offline
      yoey2112
      So 2 things really. I’d like the Calendar to take up the entire bottom 3rd of the screen.
      Second, any suggestions on making it look a little popping?
      Thanks!
      justjim1220J 2 Replies Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @yoey2112
        @yoey2112
        May I ask how you were able to show blank events?
        mine looks like this, all jumbled up and no blanks…
        Jim Hallock - 1995
          @yoey2112
          add the following to your custum.css file
           #CALEXT_month.tableStyle {
            max-width:100%;
            width:100%;
            background:none;
          Jim Hallock - 1995
            @Sean
            Do you see the calendar posted above by @yoey2112 ?
            It has blank events instead of collapsed events, I am wanting mine to look like that!
            But, I can’t figure out how to get it done!
            Jim Hallock - 1995
            • Y Offline
              yoey2112
              @justjim1220 I added that to my custom CSS but its still fairly small, a little bigger though. Is there any way to adjust the height of that location as well?
              justjim1220J 1 Reply Last reply Reply Quote 0
                @yoey2112
                what did you add? I have been looking to do this!
                the height is self-adjusting per the font sizes and line heights for the table cells.
                May be able to figure out a better way if I had the code you used to get the empty cells to show like that.
                Jim Hallock - 1995
                • ? Offline
                  A Former User @justjim1220
                  @justjim1220
                  I’ve already sent email for which was talked between us.
                  @yoey2112
                  For the whole module width;
                  .CALEXT .tableStyle {
                      margin:auto;
                      max-width: 90%; /*  change to 100%  and if you want, you can add field `width` */
                  But it will be affected by your MM body width (By default, it has some margin)
                  • Y Offline
                    yoey2112
                    @Sean Can I also adjust the height of the calendar? Example, if I wanted the Calendar to take up the entire bottom half of a Vertical screen?
                    • ? Offline
                      A Former User @yoey2112
                      @yoey2112
                      Not easy, but I think possible.
                      It looks you are using weeks (4 weeks) view, So you can adjust the height of each day slot inweeks or months view with this;
                      .CALEXT .tableStyle td.slot {
                        max-height:150px;
                        height:150px;
                      Add above codes in your css/custom.css. Adjust the value for your purpose.
                      Then, in your config,
                        views: {
                          weeks: {
                            overflowHeight:150,
                      For further details; https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                      But there could be performance issue in RPI; https://github.com/eouia/MMM-CalendarExt/wiki/Performance-Issues
                      • bokifideB Offline
                        bokifide
                        Hi! Love this module :) thank you.
                        Just wondering if there’s a way to omit Saturday and Sunday?
                        Been poking around and I haven’t been able to figure it out =/
                        Thanks ahead <3 :)
                        • 10
                        • 11
                        • 12
                        • 13
                        • 14
                        • 19
                        • 20
                        • 12 / 20
