    MMM-CalendarExt
    198 Posts 45 Posters 231.4k Views 45 Watching
    • ? Offline
      A Former User @Subintro
      @Subintro
      With MMM-CalendarExt, it’s not so easy. You just use useRelative:0 to display normal time. Anyway “CURRENT” event will not be thing of “START IN FUTURE”, It is already started and be a kind of “END IN FUTURE” things. “CURRENT” means that.
      How about using MMM-CalendarExt2? That is new build-up and the feature can be configurable and customizable by configuration.
      https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Time#2-relative
        Subintro @Guest
        @Sean
        Oh nice, I’ll check it out. Hopefully wont have to change too much with my config
          Smotx
          Little help please,
          how to reduce the height of the module?
          It adapts automatically to the content, but suddenly exceeds the top one
          alt text
          Thx a lot.
          • ? Offline
            A Former User @Smotx
            @Smotx
            See this;
            https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
              Smotx @Guest
              @Sean
              Thx for help, with your indication, i have finally used
              overflowHeight: 200,
                redink
                Is there a way to show the event start time in the same space as the even name?
                Like 6p Swim Lesson
                • ? Offline
                  A Former User @redink
                  @redink
                  More detailed adjusting might be needed, but commonly see this.
                  https://forum.magicmirror.builders/topic/4624/mmm-calendarext/148
                  And, add onlyStartingTime: 1, in your view configuration
                  • I Offline
                    isaac2004
                    Seems I cannot get the module to load. tried a few things, but it is just blank. I have the latest version of MM
                    • ? Offline
                      A Former User @isaac2004
                      @isaac2004 I need log or more detailed info to catch what happened.
                        mmmmh Project Sponsor
                        I successfully use the module on two other screens. I just set up a new one without tweaks and I run into the following error in the console (nothing gets loaded, server-side there are no errors being logged):
                        Uncaught (in promise) TypeError: hookDom.appendChild is not a function
                            at Render.js:590
                            at Array.forEach (<anonymous>)
                            at Render.drawViews (Render.js:581)
                            at Class.getDom (MMM-CalendarExt.js:209)
                            at main.js:110
                            at new Promise (<anonymous>)
                            at updateDom (main.js:109)
                            at Object.updateDom (main.js:518)
                            at Class.updateDom (module.js:358)
                            at Class.draw (MMM-CalendarExt.js:680)
                        • 14
                        • 15
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 16 / 20
