    MMM-CalendarExt
    198 Posts 45 Posters 231.4k Views 45 Watching
    • ? Offline
      A Former User @mmmmh
      @mmmmh did you set a position of view? your error says there might be an issue. I’m on a business trip now so i cannot check at this moment. later i’ll look inside.
        mmmmh Project Sponsor @Guest
        @Sean yes, I set it to top_left:
                    module: 'MMM-CalendarExt',
                    position: "top_left", //anywhere. It is not related to real position of view
                    classes: "default standard everyone",
                    config: { // Read below
                        system: {
                            show: ['current', 'upcoming'],
                            locale: 'de',
                            showEmptyView: 0,
                            fullDayEventLocalize: 1,
                            redrawInterval: 300000,
                        defaultView: {
                            position: 'calendar',
                            positionOrder: -1,
                            overflowRolling: 0,
                            overflowHeight: 0,
                            overflowDuration: 2,
                            timeFormat: 'H:mm',
                            dateFormat: "ddd, D. MMM",
                            fullDayEventDateFormat: "ddd, D. MMM",
                            ellipsis: 0,
                            limit: 20,
                            oneLineEvent: 1,
                        views: {
                            current: {
                                title: "Now...",
                                direction: "column",
                                showEmptyView: 0,
                                useRelative: 0,
                            upcoming: {
                                title: "Was steht an...",
                                useRelative: 0,
                                overflowHeight: 0,
                                overflowRolling: 0,
                                symbol: "male",
                                styleName: "style24",
                                url: "redacted",
                                auth: {
                                    user: 'redacted',
                                    pass: 'redacted',
                                    method: 'basic'
        Don’t worry, it’s not urgent.
        • ? Offline
          @mmmmh
          Well, I tried with yours and it works.
          But two things you probably have wrong.
          • url: "redacted", is it right? it will make parsing error and it could be reason of your front error message.
          • showEmptyView:1 will affect on only system level, not view level. You’ve set showEmptyView:0 in system, so empty view will not appear.
            @Sean thanks for making the effort to test it. I went the same way now. I removed everything and picked a public trash collection calendar (nice idea of yours) - still the same error. (I also commented out the showEmptyView options.)
            The error appears locally (RPI3+) as well as in web browsers of all flavors.
            Here’s the full config file:
            var config = {
                address: "",
                port: 8080,
                ipWhitelist:
                language: "de",
                timeFormat: 24,
                units: "metric",
                            system: {
                                locale: 'de',
                                // showEmptyView: 0,
                            defaultView: {
                                positionOrder: -1,
                                overflowRolling: 0,
                                overflowHeight: 0,
                                timeFormat: 'H:mm',
                                ellipsis: 0,
                                limit: 20,
                                oneLineEvent: 1,
                            views: {
                                current: {
                                    title: "Now...",
                                    useRelative: 0,
                                upcoming: {
                                    title: "Upcoming...",
                                    useRelative: 0,
                                    overflowHeight: 0,
                                    overflowRolling: 0,
                                    symbol: "male",
                                    url: "https://www.ekm-mittelsachsen.de/de/service-dienstleistungen/entsorgungstermine-abfallkalender/abfallkalender/ical/stadt/4870/year/2019/",
            • ? Offline
              @mmmmh i’m on business trip now, after back home, i’ll try your new config.
              • I Offline
                isaac2004
                Is there a way to repaint the calendar module? I am working on hiding/showing the module with voice control, and for the life of me, I can’t get the UI to repaint after hiding. module.show() is not available in the module so it is not as simple as that
                • ? Offline
                  A Former User @isaac2004
                  @isaac2004
                  Sorry, I cannot catch your point. MMM-CalendarExt can be hidden and revealed by .show() and .hide(). “module.show() is not available in the module” what this means?
                  • ? Offline
                    A Former User
                    @Sean said in MMM-CalendarExt:
                    @mmmmh I don’t know why I missed it. As I’ve said, you have a wrong on position.
                    defaultView: {
                    position should be region name like top_left, bottom_bar, … Modify it.
                    (I’m in London now, so the time of events in screenshot will not match with the German time)
                      Dang! Thanks. On my other screen I have that region and I didn’t replace it at all places! I owe you one.
                        djtale
                        Hello,
                        I have downloaded that Docker image to make some tests on MagicMirror :
                        https://hub.docker.com/r/bastilimbach/docker-magicmirror/
                        I don’t know why the MMM-CalendarExt is not displayed. I have tested multiple settings, even the simpliest provided in the doc page but still nothing appears.
                        When I use the Browser debugger, I see a size of 0x0 for the div.container
                        The calendar urls are working fine with the default calendar module.
                        Is there something missing on the Docker Image ? I doubt because I have same issue with the module on my RaspberryPi MagicMirror
                        Would someone accept to test my config module on his MagicMirror ?
                        If anyone has some ideas, thanks.
                        • 15
                        • 16
                        • 17
                        • 18
                        • 19
                        • 20
                        • 17 / 20
