    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
      Smotx @Guest
      @Sean
      Thx for help, with your indication, i have finally used
      overflowHeight: 200,
        redink
        Is there a way to show the event start time in the same space as the even name?
        Like 6p Swim Lesson
          A Former User @redink
          @redink
          More detailed adjusting might be needed, but commonly see this.
          https://forum.magicmirror.builders/topic/4624/mmm-calendarext/148
          And, add onlyStartingTime: 1, in your view configuration
          • I
            isaac2004
            Seems I cannot get the module to load. tried a few things, but it is just blank. I have the latest version of MM
              A Former User @isaac2004
              @isaac2004 I need log or more detailed info to catch what happened.
                mmmmh Project Sponsor
                I successfully use the module on two other screens. I just set up a new one without tweaks and I run into the following error in the console (nothing gets loaded, server-side there are no errors being logged):
                Uncaught (in promise) TypeError: hookDom.appendChild is not a function
                    at Render.js:590
                    at Array.forEach (<anonymous>)
                    at Render.drawViews (Render.js:581)
                    at Class.getDom (MMM-CalendarExt.js:209)
                    at main.js:110
                    at new Promise (<anonymous>)
                    at updateDom (main.js:109)
                    at Object.updateDom (main.js:518)
                    at Class.updateDom (module.js:358)
                    at Class.draw (MMM-CalendarExt.js:680)
                  A Former User @mmmmh
                  @mmmmh did you set a position of view? your error says there might be an issue. I’m on a business trip now so i cannot check at this moment. later i’ll look inside.
                    mmmmh Project Sponsor @Guest
                    @Sean yes, I set it to top_left:
                                module: 'MMM-CalendarExt',
                                position: "top_left", //anywhere. It is not related to real position of view
                                classes: "default standard everyone",
                                config: { // Read below
                                    system: {
                                        show: ['current', 'upcoming'],
                                        locale: 'de',
                                        showEmptyView: 0,
                                        fullDayEventLocalize: 1,
                                        redrawInterval: 300000,
                                    defaultView: {
                                        position: 'calendar',
                                        positionOrder: -1,
                                        overflowRolling: 0,
                                        overflowHeight: 0,
                                        overflowDuration: 2,
                                        timeFormat: 'H:mm',
                                        dateFormat: "ddd, D. MMM",
                                        fullDayEventDateFormat: "ddd, D. MMM",
                                        ellipsis: 0,
                                        limit: 20,
                                        oneLineEvent: 1,
                                    views: {
                                        current: {
                                            title: "Now...",
                                            direction: "column",
                                            showEmptyView: 0,
                                            useRelative: 0,
                                        upcoming: {
                                            title: "Was steht an...",
                                            useRelative: 0,
                                            overflowHeight: 0,
                                            overflowRolling: 0,
                                            symbol: "male",
                                            styleName: "style24",
                                            url: "redacted",
                                            auth: {
                                                user: 'redacted',
                                                pass: 'redacted',
                                                method: 'basic'
                    Don’t worry, it’s not urgent.
                      @mmmmh
                      Well, I tried with yours and it works.
                      But two things you probably have wrong.
                      • url: "redacted", is it right? it will make parsing error and it could be reason of your front error message.
                      • showEmptyView:1 will affect on only system level, not view level. You’ve set showEmptyView:0 in system, so empty view will not appear.
                        @Sean thanks for making the effort to test it. I went the same way now. I removed everything and picked a public trash collection calendar (nice idea of yours) - still the same error. (I also commented out the showEmptyView options.)
                        The error appears locally (RPI3+) as well as in web browsers of all flavors.
                        Here’s the full config file:
                        var config = {
                            address: "",
                            port: 8080,
                            ipWhitelist:
                            language: "de",
                            timeFormat: 24,
                            units: "metric",
                                        system: {
                                            locale: 'de',
                                            // showEmptyView: 0,
                                        defaultView: {
                                            positionOrder: -1,
                                            overflowRolling: 0,
                                            overflowHeight: 0,
                                            timeFormat: 'H:mm',
                                            ellipsis: 0,
                                            limit: 20,
                                            oneLineEvent: 1,
                                        views: {
                                            current: {
                                                title: "Now...",
                                                useRelative: 0,
                                            upcoming: {
                                                title: "Upcoming...",
                                                useRelative: 0,
                                                overflowHeight: 0,
                                                overflowRolling: 0,
                                                symbol: "male",
                                                url: "https://www.ekm-mittelsachsen.de/de/service-dienstleistungen/entsorgungstermine-abfallkalender/abfallkalender/ical/stadt/4870/year/2019/",
                          @mmmmh i’m on business trip now, after back home, i’ll try your new config.
                          • I
                            isaac2004
                            Is there a way to repaint the calendar module? I am working on hiding/showing the module with voice control, and for the life of me, I can’t get the UI to repaint after hiding. module.show() is not available in the module so it is not as simple as that
                              @isaac2004
                              Sorry, I cannot catch your point. MMM-CalendarExt can be hidden and revealed by .show() and .hide(). “module.show() is not available in the module” what this means?
                                A Former User
                                @Sean said in MMM-CalendarExt:
                                @mmmmh I don’t know why I missed it. As I’ve said, you have a wrong on position.
                                defaultView: {
                                position should be region name like top_left, bottom_bar, … Modify it.
                                (I’m in London now, so the time of events in screenshot will not match with the German time)
                                  Dang! Thanks. On my other screen I have that region and I didn’t replace it at all places! I owe you one.
                                    djtale
                                    I have downloaded that Docker image to make some tests on MagicMirror :
                                    https://hub.docker.com/r/bastilimbach/docker-magicmirror/
                                    I don’t know why the MMM-CalendarExt is not displayed. I have tested multiple settings, even the simpliest provided in the doc page but still nothing appears.
                                    When I use the Browser debugger, I see a size of 0x0 for the div.container
                                    The calendar urls are working fine with the default calendar module.
                                    Is there something missing on the Docker Image ? I doubt because I have same issue with the module on my RaspberryPi MagicMirror
                                    Would someone accept to test my config module on his MagicMirror ?
                                    If anyone has some ideas, thanks.
                                      A Former User @djtale
                                      @djtale
                                      Leave the issue on github with your configuration.
                                        Doudy
                                        I would like to decrease the size of characters in “{
                                        module: ‘MMM-CalendarExt’,” “calendars: [”
                                        In title and description.
                                        How to do this?
                                          Robtrowb
                                          How can I adjust the height and ad the month to the daily header? 0_1559396459084_Screen Shot 2019-06-01 at 9.39.00 AM.png
                                          I want it to say 1 June Sat, 2 June Sun and so on & adjust the height
                                          RT
                                            A Former User
                                            @Doudy @Robtrowb
                                            1)Left side of slot header would be title and Right side would be subtitle. So you can formatting with titleFormat and subtitleFormat.
                                            By example;
                                            titleFormat: "D MMM ddd",
                                            subtitleFormat: " ",
                                            would be
                                            Or,
                                            titleFormat: " ",
                                            subtitleFormat: "D MMM ddd",
                                            would be
                                            Or,
                                            titleFormat: "D MMM",
                                            subtitleFormat: "ddd",
                                            would be
                                            1. CSS Selectors of title and description would be .CALEXT .eventContent and .CALEXT .eventDescription. So if you add this into css/custom.css you can get smaller title.
                                            .CALEXT .eventContent {
                                              font-size:10px;
                                            Read https://github.com/eouia/MMM-CalendarExt/wiki and try by yourself.
                                            • 10
                                            • 9 / 10
