    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
      A Former User @redink
      @redink
      More detailed adjusting might be needed, but commonly see this.
      https://forum.magicmirror.builders/topic/4624/mmm-calendarext/148
      And, add onlyStartingTime: 1, in your view configuration
      • I
        isaac2004
        Seems I cannot get the module to load. tried a few things, but it is just blank. I have the latest version of MM
          A Former User @isaac2004
          @isaac2004 I need log or more detailed info to catch what happened.
            mmmmh Project Sponsor
            I successfully use the module on two other screens. I just set up a new one without tweaks and I run into the following error in the console (nothing gets loaded, server-side there are no errors being logged):
            Uncaught (in promise) TypeError: hookDom.appendChild is not a function
                at Render.js:590
                at Array.forEach (<anonymous>)
                at Render.drawViews (Render.js:581)
                at Class.getDom (MMM-CalendarExt.js:209)
                at main.js:110
                at new Promise (<anonymous>)
                at updateDom (main.js:109)
                at Object.updateDom (main.js:518)
                at Class.updateDom (module.js:358)
                at Class.draw (MMM-CalendarExt.js:680)
              A Former User @mmmmh
              @mmmmh did you set a position of view? your error says there might be an issue. I’m on a business trip now so i cannot check at this moment. later i’ll look inside.
                mmmmh Project Sponsor @Guest
                @Sean yes, I set it to top_left:
                            module: 'MMM-CalendarExt',
                            position: "top_left", //anywhere. It is not related to real position of view
                            classes: "default standard everyone",
                            config: { // Read below
                                system: {
                                    show: ['current', 'upcoming'],
                                    locale: 'de',
                                    showEmptyView: 0,
                                    fullDayEventLocalize: 1,
                                    redrawInterval: 300000,
                                defaultView: {
                                    position: 'calendar',
                                    positionOrder: -1,
                                    overflowRolling: 0,
                                    overflowHeight: 0,
                                    overflowDuration: 2,
                                    timeFormat: 'H:mm',
                                    dateFormat: "ddd, D. MMM",
                                    fullDayEventDateFormat: "ddd, D. MMM",
                                    ellipsis: 0,
                                    limit: 20,
                                    oneLineEvent: 1,
                                views: {
                                    current: {
                                        title: "Now...",
                                        direction: "column",
                                        showEmptyView: 0,
                                        useRelative: 0,
                                    upcoming: {
                                        title: "Was steht an...",
                                        useRelative: 0,
                                        overflowHeight: 0,
                                        overflowRolling: 0,
                                        symbol: "male",
                                        styleName: "style24",
                                        url: "redacted",
                                        auth: {
                                            user: 'redacted',
                                            pass: 'redacted',
                                            method: 'basic'
                Don’t worry, it’s not urgent.
                  @mmmmh
                  Well, I tried with yours and it works.
                  But two things you probably have wrong.
                  • url: "redacted", is it right? it will make parsing error and it could be reason of your front error message.
                  • showEmptyView:1 will affect on only system level, not view level. You’ve set showEmptyView:0 in system, so empty view will not appear.
                    @Sean thanks for making the effort to test it. I went the same way now. I removed everything and picked a public trash collection calendar (nice idea of yours) - still the same error. (I also commented out the showEmptyView options.)
                    The error appears locally (RPI3+) as well as in web browsers of all flavors.
                    Here’s the full config file:
                    var config = {
                        address: "",
                        port: 8080,
                        ipWhitelist:
                        language: "de",
                        timeFormat: 24,
                        units: "metric",
                                    system: {
                                        locale: 'de',
                                        // showEmptyView: 0,
                                    defaultView: {
                                        positionOrder: -1,
                                        overflowRolling: 0,
                                        overflowHeight: 0,
                                        timeFormat: 'H:mm',
                                        ellipsis: 0,
                                        limit: 20,
                                        oneLineEvent: 1,
                                    views: {
                                        current: {
                                            title: "Now...",
                                            useRelative: 0,
                                        upcoming: {
                                            title: "Upcoming...",
                                            useRelative: 0,
                                            overflowHeight: 0,
                                            overflowRolling: 0,
                                            symbol: "male",
                                            url: "https://www.ekm-mittelsachsen.de/de/service-dienstleistungen/entsorgungstermine-abfallkalender/abfallkalender/ical/stadt/4870/year/2019/",
                      @mmmmh i’m on business trip now, after back home, i’ll try your new config.
                      • I
                        isaac2004
                        Is there a way to repaint the calendar module? I am working on hiding/showing the module with voice control, and for the life of me, I can’t get the UI to repaint after hiding. module.show() is not available in the module so it is not as simple as that
                          @isaac2004
                          Sorry, I cannot catch your point. MMM-CalendarExt can be hidden and revealed by .show() and .hide(). “module.show() is not available in the module” what this means?
                            A Former User
                            @Sean said in MMM-CalendarExt:
                            @mmmmh I don’t know why I missed it. As I’ve said, you have a wrong on position.
                            defaultView: {
                            position should be region name like top_left, bottom_bar, … Modify it.
                            (I’m in London now, so the time of events in screenshot will not match with the German time)
                              Dang! Thanks. On my other screen I have that region and I didn’t replace it at all places! I owe you one.
                                djtale
                                I have downloaded that Docker image to make some tests on MagicMirror :
                                https://hub.docker.com/r/bastilimbach/docker-magicmirror/
                                I don’t know why the MMM-CalendarExt is not displayed. I have tested multiple settings, even the simpliest provided in the doc page but still nothing appears.
                                When I use the Browser debugger, I see a size of 0x0 for the div.container
                                The calendar urls are working fine with the default calendar module.
                                Is there something missing on the Docker Image ? I doubt because I have same issue with the module on my RaspberryPi MagicMirror
                                Would someone accept to test my config module on his MagicMirror ?
                                If anyone has some ideas, thanks.
                                  A Former User @djtale
                                  @djtale
                                  Leave the issue on github with your configuration.
                                    Doudy
                                    I would like to decrease the size of characters in “{
                                    module: ‘MMM-CalendarExt’,” “calendars: [”
                                    In title and description.
                                    How to do this?
                                      Robtrowb
                                      How can I adjust the height and ad the month to the daily header? 0_1559396459084_Screen Shot 2019-06-01 at 9.39.00 AM.png
                                      I want it to say 1 June Sat, 2 June Sun and so on & adjust the height
                                      RT
                                        A Former User
                                        @Doudy @Robtrowb
                                        1)Left side of slot header would be title and Right side would be subtitle. So you can formatting with titleFormat and subtitleFormat.
                                        By example;
                                        titleFormat: "D MMM ddd",
                                        subtitleFormat: " ",
                                        would be
                                        Or,
                                        titleFormat: " ",
                                        subtitleFormat: "D MMM ddd",
                                        would be
                                        Or,
                                        titleFormat: "D MMM",
                                        subtitleFormat: "ddd",
                                        would be
                                        1. CSS Selectors of title and description would be .CALEXT .eventContent and .CALEXT .eventDescription. So if you add this into css/custom.css you can get smaller title.
                                        .CALEXT .eventContent {
                                          font-size:10px;
                                        Read https://github.com/eouia/MMM-CalendarExt/wiki and try by yourself.
                                          Robtrowb @Guest
                                          @Sean TY
                                          • N
                                            nobita @Guest
                                            @Sean
                                            How can i solve this problem like photo
                                            the width of column not match the width of symbol
                                            Thanks for your help
                                            • 10
                                            • 9 / 10
