    MMM-CalendarExt
    198 Posts 45 Posters 271.8k Views 45 Watching
    • I
      isaac2004
      Seems I cannot get the module to load. tried a few things, but it is just blank. I have the latest version of MM
        A Former User @isaac2004
        @isaac2004 I need log or more detailed info to catch what happened.
          mmmmh Project Sponsor
          I successfully use the module on two other screens. I just set up a new one without tweaks and I run into the following error in the console (nothing gets loaded, server-side there are no errors being logged):
          Uncaught (in promise) TypeError: hookDom.appendChild is not a function
              at Render.js:590
              at Array.forEach (<anonymous>)
              at Render.drawViews (Render.js:581)
              at Class.getDom (MMM-CalendarExt.js:209)
              at main.js:110
              at new Promise (<anonymous>)
              at updateDom (main.js:109)
              at Object.updateDom (main.js:518)
              at Class.updateDom (module.js:358)
              at Class.draw (MMM-CalendarExt.js:680)
            A Former User @mmmmh
            @mmmmh did you set a position of view? your error says there might be an issue. I’m on a business trip now so i cannot check at this moment. later i’ll look inside.
              mmmmh Project Sponsor @Guest
              @Sean yes, I set it to top_left:
                          module: 'MMM-CalendarExt',
                          position: "top_left", //anywhere. It is not related to real position of view
                          classes: "default standard everyone",
                          config: { // Read below
                              system: {
                                  show: ['current', 'upcoming'],
                                  locale: 'de',
                                  showEmptyView: 0,
                                  fullDayEventLocalize: 1,
                                  redrawInterval: 300000,
                              defaultView: {
                                  position: 'calendar',
                                  positionOrder: -1,
                                  overflowRolling: 0,
                                  overflowHeight: 0,
                                  overflowDuration: 2,
                                  timeFormat: 'H:mm',
                                  dateFormat: "ddd, D. MMM",
                                  fullDayEventDateFormat: "ddd, D. MMM",
                                  ellipsis: 0,
                                  limit: 20,
                                  oneLineEvent: 1,
                              views: {
                                  current: {
                                      title: "Now...",
                                      direction: "column",
                                      showEmptyView: 0,
                                      useRelative: 0,
                                  upcoming: {
                                      title: "Was steht an...",
                                      useRelative: 0,
                                      overflowHeight: 0,
                                      overflowRolling: 0,
                                      symbol: "male",
                                      styleName: "style24",
                                      url: "redacted",
                                      auth: {
                                          user: 'redacted',
                                          pass: 'redacted',
                                          method: 'basic'
              Don’t worry, it’s not urgent.
                @mmmmh
                Well, I tried with yours and it works.
                But two things you probably have wrong.
                • url: "redacted", is it right? it will make parsing error and it could be reason of your front error message.
                • showEmptyView:1 will affect on only system level, not view level. You’ve set showEmptyView:0 in system, so empty view will not appear.
                  @Sean thanks for making the effort to test it. I went the same way now. I removed everything and picked a public trash collection calendar (nice idea of yours) - still the same error. (I also commented out the showEmptyView options.)
                  The error appears locally (RPI3+) as well as in web browsers of all flavors.
                  Here’s the full config file:
                  var config = {
                      address: "",
                      port: 8080,
                      ipWhitelist:
                      language: "de",
                      timeFormat: 24,
                      units: "metric",
                                  system: {
                                      locale: 'de',
                                      // showEmptyView: 0,
                                  defaultView: {
                                      positionOrder: -1,
                                      overflowRolling: 0,
                                      overflowHeight: 0,
                                      timeFormat: 'H:mm',
                                      ellipsis: 0,
                                      limit: 20,
                                      oneLineEvent: 1,
                                  views: {
                                      current: {
                                          title: "Now...",
                                          useRelative: 0,
                                      upcoming: {
                                          title: "Upcoming...",
                                          useRelative: 0,
                                          overflowHeight: 0,
                                          overflowRolling: 0,
                                          symbol: "male",
                                          url: "https://www.ekm-mittelsachsen.de/de/service-dienstleistungen/entsorgungstermine-abfallkalender/abfallkalender/ical/stadt/4870/year/2019/",
                    @mmmmh i’m on business trip now, after back home, i’ll try your new config.
                    • I
                      isaac2004
                      Is there a way to repaint the calendar module? I am working on hiding/showing the module with voice control, and for the life of me, I can’t get the UI to repaint after hiding. module.show() is not available in the module so it is not as simple as that
                        @isaac2004
                        Sorry, I cannot catch your point. MMM-CalendarExt can be hidden and revealed by .show() and .hide(). “module.show() is not available in the module” what this means?
                          A Former User
                          @Sean said in MMM-CalendarExt:
                          @mmmmh I don’t know why I missed it. As I’ve said, you have a wrong on position.
                          defaultView: {
                          position should be region name like top_left, bottom_bar, … Modify it.
                          (I’m in London now, so the time of events in screenshot will not match with the German time)
                            Dang! Thanks. On my other screen I have that region and I didn’t replace it at all places! I owe you one.
                              djtale
                              I have downloaded that Docker image to make some tests on MagicMirror :
                              https://hub.docker.com/r/bastilimbach/docker-magicmirror/
                              I don’t know why the MMM-CalendarExt is not displayed. I have tested multiple settings, even the simpliest provided in the doc page but still nothing appears.
                              When I use the Browser debugger, I see a size of 0x0 for the div.container
                              The calendar urls are working fine with the default calendar module.
                              Is there something missing on the Docker Image ? I doubt because I have same issue with the module on my RaspberryPi MagicMirror
                              Would someone accept to test my config module on his MagicMirror ?
                              If anyone has some ideas, thanks.
                                A Former User @djtale
                                @djtale
                                Leave the issue on github with your configuration.
                                  Doudy
                                  I would like to decrease the size of characters in “{
                                  module: ‘MMM-CalendarExt’,” “calendars: [”
                                  In title and description.
                                  How to do this?
                                    Robtrowb
                                    How can I adjust the height and ad the month to the daily header? 0_1559396459084_Screen Shot 2019-06-01 at 9.39.00 AM.png
                                    I want it to say 1 June Sat, 2 June Sun and so on & adjust the height
                                    RT
                                      A Former User
                                      @Doudy @Robtrowb
                                      1)Left side of slot header would be title and Right side would be subtitle. So you can formatting with titleFormat and subtitleFormat.
                                      By example;
                                      titleFormat: "D MMM ddd",
                                      subtitleFormat: " ",
                                      would be
                                      Or,
                                      titleFormat: " ",
                                      subtitleFormat: "D MMM ddd",
                                      would be
                                      Or,
                                      titleFormat: "D MMM",
                                      subtitleFormat: "ddd",
                                      would be
                                      1. CSS Selectors of title and description would be .CALEXT .eventContent and .CALEXT .eventDescription. So if you add this into css/custom.css you can get smaller title.
                                      .CALEXT .eventContent {
                                        font-size:10px;
                                      Read https://github.com/eouia/MMM-CalendarExt/wiki and try by yourself.
                                        Robtrowb @Guest
                                        @Sean TY
                                        • N
                                          nobita @Guest
                                          @Sean
                                          How can i solve this problem like photo
                                          the width of column not match the width of symbol
                                          Thanks for your help
                                            A Former User @nobita
                                            @nobita
                                            Basically It should be resized. but your custom css modification might be the reason of preventing works.
                                            How have you modified?
                                            • 10
                                            • 9 / 10
