    MMM-CalendarExt
    198 Posts 45 Posters 276.2k Views 45 Watching
      A Former User @isaac2004
      @isaac2004
      Sorry, I cannot catch your point. MMM-CalendarExt can be hidden and revealed by .show() and .hide(). “module.show() is not available in the module” what this means?
        A Former User
        @Sean said in MMM-CalendarExt:
        did you set a position of view? your error says there might be an issue.
        @mmmmh I don’t know why I missed it. As I’ve said, you have a wrong on position.
        defaultView: {
                            position: 'calendar',
        position should be region name like top_left, bottom_bar, … Modify it.
        (I’m in London now, so the time of events in screenshot will not match with the German time)
          mmmmh Project Sponsor
          Dang! Thanks. On my other screen I have that region and I didn’t replace it at all places! I owe you one.
            djtale
            I have downloaded that Docker image to make some tests on MagicMirror :
            https://hub.docker.com/r/bastilimbach/docker-magicmirror/
            I don’t know why the MMM-CalendarExt is not displayed. I have tested multiple settings, even the simpliest provided in the doc page but still nothing appears.
            When I use the Browser debugger, I see a size of 0x0 for the div.container
            The calendar urls are working fine with the default calendar module.
            Is there something missing on the Docker Image ? I doubt because I have same issue with the module on my RaspberryPi MagicMirror
            Would someone accept to test my config module on his MagicMirror ?
            If anyone has some ideas, thanks.
            ? 1 Reply Last reply
              A Former User @djtale
              @djtale
              Leave the issue on github with your configuration.
                Doudy
                I would like to decrease the size of characters in “{
                module: ‘MMM-CalendarExt’,” “calendars: [”
                In title and description.
                How to do this?
                  Robtrowb
                  How can I adjust the height and ad the month to the daily header? 0_1559396459084_Screen Shot 2019-06-01 at 9.39.00 AM.png
                  I want it to say 1 June Sat, 2 June Sun and so on & adjust the height
                  RT
                    A Former User
                    @Doudy @Robtrowb
                    1)Left side of slot header would be title and Right side would be subtitle. So you can formatting with titleFormat and subtitleFormat.
                    By example;
                    titleFormat: "D MMM ddd",
                    subtitleFormat: " ",
                    would be
                    Or,
                    titleFormat: " ",
                    subtitleFormat: "D MMM ddd",
                    would be
                    Or,
                    titleFormat: "D MMM",
                    subtitleFormat: "ddd",
                    would be
                    1. CSS Selectors of title and description would be .CALEXT .eventContent and .CALEXT .eventDescription. So if you add this into css/custom.css you can get smaller title.
                    .CALEXT .eventContent {
                      font-size:10px;
                    Read https://github.com/eouia/MMM-CalendarExt/wiki and try by yourself.
                    R 1 Reply Last reply
                      Robtrowb @Guest
                      @Sean TY
                      • N
                        nobita @Guest
                        @Sean
                        How can i solve this problem like photo
                        the width of column not match the width of symbol
                        Thanks for your help
                        ? 2 Replies Last reply
                          A Former User @nobita
                          @nobita
                          Basically It should be resized. but your custom css modification might be the reason of preventing works.
                          How have you modified?
                            @nobita
                            Or where have you placed the month view? That view is such a wide so it will not fit in smaller area for displaying normally.
                              JonOpelGT
                              Hello, I’m working with CalendarExt. Its a great module! Ihave a small feature request that would be very helpful to me. currently there are several views “upcoming,” “current,” etc. I would like to request a “recent” view which shows items in the recent past. This should be fairly straitforward. What is the process to get an addition like that? Thanks.
                              • N
                                Newtothis
                                Hi, great looking module.
                                Would you be able to post your config for the first screenshot please? I am having trouble working out the config.
                                  dolszews89
                                  I can´t seem to enable the event time (eg. 17:00-19:00 next to the event title), what might be the problem here?
                                  Well, I assumed in month view and weeks view people might not need exact time, (Mirror is too small to display many things), So I disabled it by default.
                                  Add this to your css/custom.css
                                  div.CALEXT div.tableStyle div.eventContainer div.eventTime {
                                    display:block;
                                  This is from a while ago but I am running into a problem. I would also like to add time stamps to my month view. I have add the recommended code to the end of my custom.css file but the time stamps still do not appear. Should be code refer to the “month” view somewhere?
                                    A Former User @dolszews89
                                    @dolszews89
                                    I don’t recommend to display event time on tableStyle (weeks, month), but if you want,
                                    Add this into your css/custom.css
                                    .CALEXT .tableStyle .eventTime {
                                      display:block;
                                      font-size:10px;
                                    .CALEXT .tableStyle .fulldayevent  .eventTime {
                                      display:block;
                                      font-size:10px;
                                    PS : There is no other modification in my css/custom.css
                                      migitcheetah
                                      Is there a way to set my month view to start on Monday instead of Sunday? I have events that are Monday through Sunsay, and would like to avoid them wrapping from one line to the next, and instead have them on one single line from Monday to Sunday.
                                        A Former User @migitcheetah
                                        @migitcheetah
                                        It depends on your locale.
                                        M 1 Reply Last reply
                                          migitcheetah @Guest
                                          @Sean ok,
                                          How would I know which locals have a monday start date, and would that change the entire mirrors language? Can I change local just for the calendar?
                                            @migitcheetah
                                            So, what is your default language of MM?
                                            https://github.com/eouia/MMM-CalendarExt/wiki/Configuration#system
                                            If you are using English, use en-GB. In UK, a week would start from Monday. (but in US, starts from Sunday.)
                                            • 10
                                            • 9 / 10
