    MMM-Tools : System stat monitoring and commanding (ATB Supported)
    38 Posts 7 Posters 20.6k Views 6 Watching
    • ? Offline
      A Former User @Kimzer
      @Kimzer that might be related with width vlaue. That might be not bug. I don’t assume how much width user assign to my module. So you could adjust your GOOD view with css by yourself. Give your favorite width or min-width to the module in css.
      Anyway, someone could feel embarrassed with this inconvenient approach, I’ll add default min-width value in next commit.
      Thanks for your advice.
      • randomnoiseR Offline
        randomnoise @Kimzer
        @Kimzer @Sean
        Yup, can confirm it works just fine in top_left… my top left width happens to be manually set to be 480px due to another module I’m running so that’s probably why its happy now.
        BTW I forgot to set to RPI, but it actually still worked just fine when set to ATB by default.
        • ? Offline
          A Former User @randomnoise
          @randomnoise screen controlling and measuring temperatures are different between rpi and atb.
          randomnoiseR 1 Reply Last reply Reply Quote 0
          • KimzerK Offline
            Kimzer
            Probably not a bug at all, may be my custom css that is causing issues.
            Tried min-width and width but really didnt fix anything.
              randomnoise @Guest
              @Sean I’m not using the screen controls so that’s fair enough. I just compared the temp from MMM-Tools to that from MMM-system stats and yes you’re correct the values are wrong if I set the type to ATB. Forgive my rambling :)
              • ? Offline
                @Kimzer ok, tomorrow i’ll try testing widely and can provide better settings. Sorry for inconvenience of all and thanks for your interesting. After work, I’ll post about that.
                • KimzerK Offline
                  Kimzer
                  Great stuff! :) Seems like i can run the module fine anywhere but the bottom rows.
                  ? 2 Replies Last reply Reply Quote 0
                  • ? Offline
                    @Kimzer You are right. that is so weird, only in the bottom region, it won’t works. I’d never imagined this.
                    But, now I catch this error, I believe I can solve this problem.
                    • ? Offline
                      @Kimzer Here is hotfix.
                      open MMM-Tools.css, find below section, add margin-top:0; there.
                      .Tools .status_item .container {
                        width: 75%;
                        order: 2;
                        height:100%;
                        overflow:hidden;
                        margin-top:0;
                      MM’s default main.css set margin-top:25px; to .bottom .bar, It makes collision with my css.
                      • KimzerK Offline
                        Kimzer
                        Perfect. I just included it in my custom.css
                        Thanks for the fix! :D
                        • 3 / 4
