MMM-Tools : System stat monitoring and commanding (ATB Supported)
38 Posts 7 Posters 17.5k Views
  • K
    Kimzer
    Any way to make the bars showing ram be transparent?
    ? 1 Reply Last reply Sep 4, 2017, 10:30 AM Reply Quote 0
      A Former User @Kimzer
      @Kimzer in css, change #xxx to rgba(00,00,00,0.5) which you want.
      Ex) rgba(255,0,0,0.5) will be half-transparent red.
      • K
        Kimzer
        Went another way and used opacity. Worked great :)
        • L
          lavolp3 Module Developer
          @Sean Hi Sean,
          the module does not show correct values for SD card space for me.
          Actual values:
          Shown values:
          Any idea?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • L
            I think you need to use sudo du -hs / instead of du -hs to show usage of all folders. This shows me the 6.5G my system is using instead of the 1.5G which is not enough and supposedly only valid for part of the system.
            ? 1 Reply Last reply Oct 15, 2018, 8:39 AM Reply Quote 0
              A Former User @lavolp3
              @lavolp3
              Thanks for information. I’ll fix it later, however you can modify the source on line 34 of node_helper.js.
              L 1 Reply Last reply Oct 15, 2018, 9:10 AM Reply Quote 0
              • L
                lavolp3 Module Developer @A Former User
                @sean Also, I think you could cut the line so the dash, or in your case the dot, does not appear.
                If I find the time I’ll send a PR.
                  A Former User
                  UPDATED
                  2019-01-13
                  • Voice warning alert be enabled with MMM-AssistantMk2
                  • 4 / 4
