    MMM Remote dont work after update
    6 Posts 4 Posters 4.4k Views 4 Watching
      shotput2017
      Hi!
      First off all… THX for this great software. I made a update today. The new fonts look great.
      Unfortunately the modul remote does not work anymore after the update. The Remotes page can no longer be called
      http: //xx.xx.xx.xx: 8080 / remote.html
      Please help.
      best regards
      shotput2017
        shotput2017
        my IP White list:
        ipWhitelist: [
        “10.0.0.1/24”,
        “::ffff:10.0.0.1/120”,
        “127.0.0.1”,
        “::ffff:127.0.0.1”,
        “::1”
        • randomnoiseR
          randomnoise
          Due to a change in one of the default configuration items since the latest version came out you need to put
          address:“0.0.0.0”,
          As a config item (not in your whitelist… This is a new line for your config)
          Note, setting to 0.0.0.0 is telling the mirror to use any interface. If you want you could replace that with your mirror’s ip address.
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @shotput2017
            @shotput2017
            As @randomnoise pointed out, editing your config.js file like this will solve your connection problem to the Remote-Control module
            var config = {
            	address: "0.0.0.0", // "localhost", // Address to listen on, can be:
            You can see that it is running on my MacBuntu and my iPhone. To use it remotely you still have to use http://192.168.1.21:8080/remote.html as your url but to view the mirror itself remotely you need to use http://192.168.1.21:8080/, at least in my case.
              shotput2017
              @Mykle1 said in MMM Remote dont work after update:
              address: “0.0.0.0”, // “localhost”, // Address to listen on, can be:
              hi mykle1 and randomnoise!
              thx for help. adding the adress line to config.js fixed the problem :-)
              greets
              shotput2017
              • F
                fox
                After update it started with the same problem at me.
                First remote was down, then i made the fix from @roramirez :
                https://forum.magicmirror.builders/post/28921
                and now my complete MM is crashed and i dont know how to solve it.
                Only blank screen, i did several times a
                git pull & npm install
                Dont update! Never touch a running system
