    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 240.2k Views 28 Watching
      Smotx @gauka12345
      @gauka12345
      I gave found new token on Mi home app android, it worked a few days, and then again it does not work anymore, it tells me ‘time out’ and in mioo discover there is nothing at all
      { Error: Call to device timed out
      at retry (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:225:18)
      at _ensureToken.catch.err (/home/pi/MagicMirror/modules/MMM-xiaomi/node_modules/miio/lib/device.js:238:8)
      at code: ‘timeout’
      • garblefluxG
        garbleflux Project Sponsor @Smotx
        @smotx said in MMM-xiaomi - Temperature and Humidity from your smarthome:
        hi,
        Same problem here too
        I have changed my router, so i have change wifi of Xiaomi hub
        On magicmirror config i have set new ip 192.168.2.xxx (before 192.168.1.xxx).
        But always nothing on MagicMirror after reboot.
        perhaps token has changed with new router… So, on the rasp i launch command ```
        miio discover
        ` $ sudo miio discover
         INFO  Discovering devices. Press Ctrl+C to stop.
        Device ID: 567xxxx54
        Model info: Unknown
        Address: 192.168.2.xxx
        Token: ???
        Support: Unknown
        Anybody know why ? :(.
        I had the same problem. Meanwhile, I have found the solution. An update from Xiaomi changed the token in the gateway. This must now be read out via the smartphone. In my case the miio discovery command did not work any more. I followed this instruktion to get the new token
        https://forum.smartapfel.de/forum/thread/1219-xiaomi-mi-gateway-homebridge-mi-aqara/?postID=31779#post31779
        … and now all works fine again - I have all my sensors back on the mirror.
        regards
        Mike
          Smotx
          after this command :
          miio tokens update 567xxxxx --token 6xxxxxxxxxxxxxxxxxxxxxxxxxxx
          mine to work again a few days, and now is KO again… for the third time… :face_with_steam_from_nose: Token has not changed, ip has not changed…
            Serg
            I can’t find what needs to be changed in CSS to change the font color of the temperature and humidity numbers.
            • L
              lovesicker
              Hi guys,
              I have two temperature sensors. Each sensor registers with a gateway. Could anyone tell me how to add the two gateways in config.js file?
              I try to add the following codes in config.js:
              module: ‘MMM-xiaomi’,
              position: ‘top_right’,
              header: ‘Temperature / Humidity’,
              gatewayIP: ‘192.168.186.181’,
              gatewayToken: ‘xxxxxxxx-ceec093b30b1775dc741a7’,
              showWindow: true,
              showVentilation: true,
              showLights: false,
              audioNotifications: true,
              rooms: [
              sortOrder: 20,
              devices : [‘158d000xxxx9f’]
              gatewayIP: ‘192.168.186.166’,
              gatewayToken: ‘xxxxxxxx–927e2d20b22c22b007194c’,
              rooms: [
              sortOrder: 30,
              devices : [‘158d000xxxx4f6’]
              but MagicMirror always display the last sensor, which registers with the secondary gateway in config.js file.
              Could anyone give me some suggestions? Thanks in advance!
              garblefluxG 1 Reply Last reply
              • garblefluxG
                garbleflux Project Sponsor @lovesicker
                @lovesicker Hi,
                I think you are on the wrong way: You use gatewayIP and gatewayToken twice. Thats not necessary.
                Look to my configuration - this works fine:
                position: ‘bottom_left’,
                colored: true,
                header: ‘Temperatur / Luftfeuchtigkeit’, // This is optional
                gatewayIP: ‘192.168.160.xx’,
                outsideSensorId: ‘15xxx0201dxxx’,
                gatewayToken: ‘cd857eee1fc760d029767709cd50xxxx’,
                showWindow: true,
                showLights: false,
                showTend: false,
                showNotifications: false,
                audioNotifications: false,
                                    rooms:  [
                		minTemperature : 15,
                                    maxTemperature : 35,
                                    sortOrder: 1,
                		devices : ['158d0001c2cxxx']
                		sortOrder: 20,
                                    devices : ['15xxx00201d4xxx']
                                    sortOrder: 2,
                                    sortOrder: 3,
                                    maxTemperature : 30,
                                    devices : ['1xxx000201dxxx', '15xxx001f49xxx']
                                    sortOrder: 4,
                                    devices : ['1xxd0001c14xxx']
                                    sortOrder: 5,
                		devices : ['15xxx01f54xxx']
                                    minTemperature : 10,
                                    sortOrder: 7,
                		devices : ['15xxx002029xxx']
                                    sortOrder: 10,
                                    devices : ['15xxx001c1xxx']
                                    sortOrder: 9,
                                    devices : ['15xxx001c2axxx']
                                    sortOrder: 8,
                                    devices : ['15xxx001c1axxx']
                                    minTemperature : 18,
                                    sortOrder: 6,
                                    devices : ['15xxx001c2cxxx']
                L 1 Reply Last reply
                • L
                  lovesicker @garbleflux
                  @garbleflux First, thank you for your reply.
                  I have two different rooms. There are a temperature sensor and a gateway in each room! So I have to add two gateways in config.js file.
                  • garblefluxG
                    @lovesicker Hi,
                    why do you use two gateways? It’s not necessary. I use one gateway for my complete house. I use 10 temperature and humity sensors. Have a closer look to my config.
                    Regards Mike.
                    • L
                      @garbleflux thank you for your discussion.
                      It’s difficult to explain. Let me try. Maybe my scenario is very different with yours.
                      There are one Xiaomi temperature sensor, one Xiaomi air conditioning companion (gateway) and one Xiaomi intelligent clock (integrated partial AI function) in EACH bedroom.
                      When I speak to the clock, “Hi Xiaoai, please tell me the room temperature” or “temperature”, the clock tell me the correct number of degrees via the RIGHT gateway. When I say “power on the air conditioning”, the same thing happen.
                      It’s unsuitable that I say "tell me CHILDROOM temperature " or “power off CHILDROOM air conditioning” when I’m in my bedroom. Although I know it is realizable.
                      I’m not sure I clearly explain the reason. Anyway, I need two gateways in my house.
                      • garblefluxG
                        @lovesicker OK. Did you try to start the module twice? Maybe this is the possibility to activate both gateways at the same time as you need it.
                        Regards Mike
                        • L
                          @garbleflux
                          Yes, I can add two instances in config.js file at the same time.
                          YOU ARE RIGHT!
                          It’s not necessary. According to your suggestion, I register all of my sensors on ONE gateway. I can still fulfill all my needs.
                          I’m stupid. I’ve made simple things complicated.
                          Tanks again!
                          Good luck.
                          • L
                            lovesicker
                            Hi @mirko3000 ,
                            How to remove the ‘>’ symbols which in front of the temperature and humidity?
                            I try to set showTend: false, but it does not work.
                            Could you or anyone give me some suggestions? Thanks in advance.
                            • N
                              norman
                              Hello everyone,
                              is there a chance to use this module with the Aqara Gateway and the Aqara Sensors? I have a problem to find the sensors with miio. Thanks in advance!
                              Best regards!
                              StoffbeuteluweS 2 Replies Last reply
                              • StoffbeuteluweS
                                Stoffbeuteluwe Project Sponsor @norman
                                @norman if you get the token from the Aqara gateway it should work …
                                • StoffbeuteluweS
                                  @norman I have the mii gateway with aqara sensors …works fine
                                  • M
                                    mydiva
                                    Hi @mirko3000 … oooh an update… what’s new? thx…
                                    • M
                                      mag999
                                      Hi mirko3000
                                      Thanks for a great module.
                                      What gateway are you using?
                                      • N
                                        Nosaer
                                        You have no plans to increase the functionality of the module and add more sensors for display?
                                        • N
                                          Nosaer
                                          If there is no humidity sensor in the room, but there is a sensor for opening windows and doors, how does it look like?
                                          • E
                                            ectovito @Smotx
                                            @smotx
                                            Thank you Mirko3000 for this great module.
                                            I was finally able to retrieve the Device IDs via the Aqara gateway, and the tokens from the gateway and vacuum in the Miio Mac application.
                                            I can correctly display the temperature and humidity of my different rooms in the house. The same for my vaccum via the Xiaomi-vaccum module.
                                            The only thing I can’t do is to declare the door sensors and the sensory sensors.
                                            What should I declare in the configuration file?
                                            What script should be entered to display all the sensors in this way?
                                            Thank you in advance for your help.
                                            • 6
                                            • 7
                                            • 8
                                            • 7 / 8
