    MMM-xiaomi - Temperature and Humidity from your smarthome
    142 Posts 28 Posters 242.3k Views 28 Watching
    • L
      lovesicker @garbleflux
      @garbleflux thank you for your discussion.
      It’s difficult to explain. Let me try. Maybe my scenario is very different with yours.
      There are one Xiaomi temperature sensor, one Xiaomi air conditioning companion (gateway) and one Xiaomi intelligent clock (integrated partial AI function) in EACH bedroom.
      When I speak to the clock, “Hi Xiaoai, please tell me the room temperature” or “temperature”, the clock tell me the correct number of degrees via the RIGHT gateway. When I say “power on the air conditioning”, the same thing happen.
      It’s unsuitable that I say "tell me CHILDROOM temperature " or “power off CHILDROOM air conditioning” when I’m in my bedroom. Although I know it is realizable.
      I’m not sure I clearly explain the reason. Anyway, I need two gateways in my house.
      • garblefluxG
        garbleflux Project Sponsor
        @lovesicker OK. Did you try to start the module twice? Maybe this is the possibility to activate both gateways at the same time as you need it.
        Regards Mike
        L 1 Reply Last reply
        • L
          @garbleflux
          Yes, I can add two instances in config.js file at the same time.
          YOU ARE RIGHT!
          It’s not necessary. According to your suggestion, I register all of my sensors on ONE gateway. I can still fulfill all my needs.
          I’m stupid. I’ve made simple things complicated.
          Tanks again!
          Good luck.
          • L
            lovesicker
            Hi @mirko3000 ,
            How to remove the ‘>’ symbols which in front of the temperature and humidity?
            I try to set showTend: false, but it does not work.
            Could you or anyone give me some suggestions? Thanks in advance.
            • N
              norman
              Hello everyone,
              is there a chance to use this module with the Aqara Gateway and the Aqara Sensors? I have a problem to find the sensors with miio. Thanks in advance!
              Best regards!
              StoffbeuteluweS 2 Replies Last reply
              • StoffbeuteluweS
                Stoffbeuteluwe Project Sponsor @norman
                @norman if you get the token from the Aqara gateway it should work …
                • StoffbeuteluweS
                  @norman I have the mii gateway with aqara sensors …works fine
                    mydiva
                    Hi @mirko3000 … oooh an update… what’s new? thx…
                      mag999
                      Hi mirko3000
                      Thanks for a great module.
                      What gateway are you using?
                      • N
                        Nosaer
                        You have no plans to increase the functionality of the module and add more sensors for display?
                        • N
                          Nosaer
                          If there is no humidity sensor in the room, but there is a sensor for opening windows and doors, how does it look like?
                          • E
                            ectovito @Smotx
                            @smotx
                            Thank you Mirko3000 for this great module.
                            I was finally able to retrieve the Device IDs via the Aqara gateway, and the tokens from the gateway and vacuum in the Miio Mac application.
                            I can correctly display the temperature and humidity of my different rooms in the house. The same for my vaccum via the Xiaomi-vaccum module.
                            The only thing I can’t do is to declare the door sensors and the sensory sensors.
                            What should I declare in the configuration file?
                            What script should be entered to display all the sensors in this way?
                            Thank you in advance for your help.
                            • E
                              Egnos
                              Hi guys,
                              can anyone tell me if this module still works? If yes, which gateway should I purchase to make sure I can view sensor data with the MM?
                              thanks
                              R 1 Reply Last reply
                                RachaelMeadows @Egnos
                                Yes, the module still works if you use a Xiaomi BLE gateway. The easiest option is the official Xiaomi Bluetooth Gateway (Mi Smart Home Hub). Once paired, the sensor data shows up fine in MM.
                                • 7 / 8
