    GPIO without root
    Scheduled Pinned Locked Moved Solved Development
    gpiowiring-pi
    4 Posts 2 Posters 6.6k Views 1 Watching
    • P Offline
      paviro
      I am currently writing a module which uses the GPIO Pins for that the script has to be started as root. I tried running MM with DISPLAY=:0 sudo npm startbut all I get this way is a No protocol specifiederror on startup. Any idea how to fix this or how to use wiring-pi without root? Wasn’t there an Raspbian update recently that allowed GPIO access without root? I don’t remember it exactly…
      We're all stories in the end. Just make it a good one, eh?
      – The Doctor
      • K Offline
        KirAsh4 Moderator
        First Google result brings this up:
        https://dissectionbydavid.wordpress.com/2013/10/21/raspberry-pi-using-gpio-wiringpi-without-root-sudo-access/
        • P Offline
          paviro
          That’s nice and all but too complicated for people to setup…
          Adding a sudo somewhere is one thing but that would make installing the module so complicated :confused:
          Seems like it might be possible by using usermod -a -G gpio pi will check and report.
          – The Doctor
          • P Offline
            paviro
            Found a workaround! Use the shell within node to export the pins. Works without root if the user is added to the gpio group, to do that execute sudo useradd -g pi gpio.
            Setup the pins
            const exec = require('child_process').exec;
            exec("echo '22' > /sys/class/gpio/export", null);
            exec("echo 'in' > /sys/class/gpio/gpio22/direction", null);
            exec("echo '17' > /sys/class/gpio/export", null);
            exec("echo 'out' > /sys/class/gpio/gpio17/direction", null);
            Control the pins
            gpio.setup('sys');
            gpio.wiringPiISR(22, gpio.INT_EDGE_BOTH, function(delta) {
            	if (gpio.digitalRead(22) == 1) {
            		console.log("High");
            		gpio.digitalWrite(17, 1)
            	else if (gpio.digitalRead(22) == 0) {
            		console.log("Low");
            		gpio.digitalWrite(17, 0)
            – The Doctor
