    MMM-Carousel ignoreModules
    5 Posts 3 Posters 4.7k Views 3 Watching
      shgmongohh
      Hi guys,
      I have a problem with the module Carousel to ignore some modules.
      I get the failure message, that something is wrong the the MM config file, when I put in some Modules to ignore.
      Whats wrong with my config file?
      Sebastian
          module: 'MMM-Carousel',
          [clock, calender]
      • strawberry 3.141S
        You have to put the Module names in Quotes like ‘clock’
          shgmongohh @strawberry 3.141
          @strawberry-3.141
          When I put it in quotes ['clock'] I also get the failure message that something is wrong in my config file.
          • I
            ianperrin @shgmongohh
            @shgmongohh said in MMM-Carousel ignoreModules:
            It looks like you are missing both the quotes around the module names (as @strawberry-3-141 mentioned) and the name of the configuration option (i.e. ignoreModules).
            Try this version:
                    ignoreModules: ['clock', 'calendar']
            You might also want to consider adding 'alert' to the ignoreModules list as pointed out by @barnabycolby in his Configuration Options notes
            “Live as if you were to die tomorrow. Learn as if you were to live forever.” - Mahatma Gandhi
            S 1 Reply Last reply Reply Quote 2
              shgmongohh @ianperrin
              @ianperrin
              Thanks a lot.
