    Alexa pi install, mic doenst work?
    16 Posts 4 Posters 8.5k Views 4 Watching
      Milad222
      Hello everyone…
      I hope someone of you there can help me with the alexa pi…
      when i start alexa pi by sudo systemctl start AlexaPi.service and than checkinhg the status by sudo systemctl status AlexaPi.service i have got this error…
      pi@raspberrypi:~ $ sudo systemctl status AlexaPi.service
      ● AlexaPi.service - Alexa client for all your devices
      Loaded: loaded (/usr/lib/systemd/system/AlexaPi.service; enabled)
      Active: failed (Result: exit-code) since Fri 2017-10-13 18:22:22 CEST; 1min 14s ago
      Docs: https://github.com/alexa-pi/AlexaPi/wiki
      Process: 1320 ExecStart=/usr/bin/python /opt/AlexaPi/src/main.py --daemon (code=exited, status=1/FAILURE)
      Main PID: 1320 (code=exited, status=1/FAILURE)
      Oct 13 18:22:22 raspberrypi python[1320]: ALSA lib pcm.c:2239:(snd_pcm_open_…e
      Oct 13 18:22:22 raspberrypi python[1320]: ALSA lib pcm_dmix.c:1022:(snd_pcm_…e
      Oct 13 18:22:22 raspberrypi python[1320]: connect(2) call to /tmp/jack-999/d…)
      Oct 13 18:22:22 raspberrypi python[1320]: attempt to connect to server failed
      Oct 13 18:22:22 raspberrypi python[1320]: CRITICAL: Your input_device 'plugh…:
      Oct 13 18:22:22 raspberrypi python[1320]: pulse
      Oct 13 18:22:22 raspberrypi python[1320]: default
      Oct 13 18:22:22 raspberrypi systemd[1]: AlexaPi.service: main process exited…E
      Oct 13 18:22:22 raspberrypi systemd[1]: Unit AlexaPi.service entered failed …
      Hint: Some lines were ellipsized, use -l to show in full.
      i think its the sound card but i dont know how to install and configure the sound card…
      i install teamvierwer so mayb someone overthere van help me? :) thnx
      aro28A 1 Reply Last reply Reply Quote 0
      • aro28A Offline
        aro28 @Milad222
        @Milad222
        I bought USB 3D sound card adapter since my Pi3 hasn’t Mic port and than i connected my jack 3.5 Microphone to it .
        If you have another USB HD camera with built-ed Mic you have to disable it since it will not work properly with your speech recognition software. I faced recently with this problem. I couldn’t configure it.
        If you have USB HD camera with built-ed Mic please let me know and i show you how to disable it.
        Best,
          Milad222 @aro28
          @aro28 said in Alexa pi install, mic doenst work?:
          Hi Thanx for replying me, i have a logitac usb camera with buildin cam… the mic work in the pluseaudi pannel… i see it moving at the input section…
          so i think i have to disable it…? i have also teamviewer installed on my laptop you can connect me if its to difficult to explane… :)
          • ? Offline
            A Former User @Milad222
            @Milad222
            I think it could be related with permission of account.
            As I know, Alexa Pi is running with Deamon mode, it means, the account of Alexa Pi is different with your personal account which you had tested audio with.(maybe pulse audio)
            I have no idea how to solve because I’m not an expert, but most of the cases seem to be related to that point in using Alexa Pi.
              Milad222 @aro28
              This is printscreen of my settings and error…
              • ? Offline
                @Milad222
                Can you record and play with these commands? Does it work?
                arecord -d 10 test.wav && aplay test.wav
                  Milad222 @Guest
                  @Sean said in Alexa pi install, mic doenst work?:
                  Yes that works…
                    Milad222 @Milad222
                    @Milad222 said in Alexa pi install, mic doenst work?:
                    Yes that works…
                    pi@raspberrypi:~ $ arecord -d 10 test.wav && aplay test.wav
                    Recording WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                    Playing WAVE ‘test.wav’ : Unsigned 8 bit, Rate 8000 Hz, Mono
                    pi@raspberrypi:~ $
                    pi@raspberrypi:~ $ aplay test.wav
                    pi@raspberrypi:~ $
                    • ? Offline
                      @Milad222
                      I’m not an expert, but Only I can say is…
                      • The error message caused by sound configuration fail.
                      • AlexaPi cannot understand your device “plughw:…” currently.
                      • I think it is related to alexapi daemon account and your personal account settings.
                      • https://github.com/alexa-pi/AlexaPi/wiki/Audio-setup-&-debugging This could be helpful.
                      Anyway, this is not realted with MagicMirror. You’d better get help from AlexaPi develpers or users on gitHub(or wiki)
                      • aro28A Offline
                        aro28
                        Since i installed 3D sound card(external USB card with speaker and Mic) i disabled other internal HD web camera’s Microphone which came with my Touch Screen monitor. I used usual 3.5 mm jack mic.
                        1. Go to- -> sudo nano /lib/modprobe.d/aliases.conf
                        ##options snd-pcsp index=-2 - This is my USB Mic which is came with internal HD camera on my monitor.
                        options snd-usb-audio index=-2
                        options cx88_alsa index=-2
                        options snd-atiixp-modem index=-2
                        options snd-intel8x0m index=-2
                        2. Go to --> sudo nano /etc/modprobe.d/raspi-blacklist.conf and added below command
                        blacklist snd_bcm2835
                        Above “snd_bcm2835” is my internal sound card
                        That’s all.
