    Sync private iCloud calendar with MagicMirror
    162 Posts 58 Posters 409.0k Views 65 Watching
    • BehB Offline
      Beh @bgz
      Hey, @bgz! No problem, I’m glad to help if I have time for that :)
      first: the path should be /home/pi/.vdirsyncer/config you forgot the slash after “pi”
      additionally, it seems, that the folder does not exist. Please make sure, that the folder .vdirsyncer exists in your user’s home directory. You can create it by typing mkdir .vdirsyncer when you are inside the home directory
        bgz
        Hi Beh.
        For some reason I have no .vdirsyncer directory under /home/pi/
        Any ideas?
        Thanks for your patience.
        bgz
        BehB schwoediauerS 2 Replies Last reply Reply Quote 0
        • BehB Offline
          Beh @bgz
          @bgz Please read answers carefully. If it doesn’t exist, just create it. I described the creation in my last answer.
            Mykle1 Project Sponsor Module Developer @Beh
            @Beh said in Sync private iCloud calendar with MagicMirror:
            Amen
            • schwoediauerS Offline
              schwoediauer @Beh
              @Beh Hi Beh, great work it’s a little bit tricky but it works fine on my side. One additional Information. I got an error by syncing after modification of an event on iCloud side. Therefore is necessary to modify the conflict_resolution in the config file as described here: https://vdirsyncer.pimutils.org/en/stable/config.html#pair-section
              I added this section in my configuration:
              CALDAV Sync
              [pair iCloud_to_MagicMirror]
              a = “Mirror”
              b = “iCloud”
              collections = [“65CFC60E-8888-4B7A-B8DB-0043A969A041”]
              conflict_resolution = “b wins”
              after first sync…
              pi@pi_mirror:/etc/systemd/user $ /usr/bin/vdirsyncer sync
              Syncing iCloud_to_MagicMirror/65CFC60E-8888-4B7A-B8DB-0043A969A041
              Doing conflict resolution for item 247C105F-156B-41DC-B1D6-BFDB7C753BDC…
              second sync imports the modified event in my .ics file
              have a nice Day!
                schwoediauer @bgz
                @bgz Good morning Create an “hidden” folder by command mkdir .vdirsyncer, and check it by command ls - lisa
                  ribermon
                  Also you have to create first the file, it does not exist, so first create it following the path said by Beh and inside the folder create the file
                  • ildottoreI Offline
                    ildottore
                    @Beh: First I want to thank you for this tutorial! Great job!
                    It syncs my iCloud calender fine, but not birthdays which are placed from the contacts app.
                    Can someone advice me?
                    Thanks in advance!
                    BehB 1 Reply Last reply Reply Quote 0
                      bgz @schwoediauer
                      @schwoediauer
                      Thanks schwoediauer and the others.
                      I finally got it and it is up & syncing!!
                      • BehB Offline
                        Beh @ildottore
                        @ildottore I configured the syncer config to only synchronize calendar events with the property item_types = ["VEVENT"]. The CalDav function only supports the items like "VEVENT" and "VTODO".
                        I think, that iOS/macOS does not store the birthdays directly in the calendars but adds the birthdays via the Contacts.app to the Calendar.app.
                        Maybe you can achieve showing birthdays by syncing the contacts with vdirsyncer as described in the docs here and somehow extract the birthdays. But I think this would be quite costly…
                        Or you can use the MagicMirror module MMM-iCloud-Client maybe…
                        • G Offline
                          ganther
                          Hi there,
                          i followed the instructions, my calendars are shown in discovery.
                          I copied the UUID and it starts syncing, but the saved files are 0kb.
                          I tried several calendars and checked the UUID’s but can’t find any mistake?
                          any ideas?
                          thanks!!
                          • G Offline
                            Gailby @Beh
                            @Beh Everything works fine until I’ll try to save the config file:
                            1. ~/.vdirsyncer/config directory cannot be found
                            2. Once I manuals create directories I also save config file as config.cfg and also tried config.config and save
                            3. I haven’t filled in collections = [“HERE-GOES-THE-UUID-OF-THE-CALENDAR-YOU-WANT-TO-SYNC”] in conf. Could this make it crash?
                            4. Running curl for timer ok.
                              5.Then when vdirsyncer discover nothing happens I get Errno 21 and that’s where I get stuck…
                            Really wonder what might be the issues here?
                            • G Offline
                              ganther @Gailby
                              @Gailby
                              The file is named config. It‘s not a directory, it‘s the name of the file. (No ending).
                              • G Offline
                                Gailby @ganther
                                @ganther so if I put config in ~/.vdirsyncer/config it should work?
                                I think I did try it but somehow wansn’t able to read it as a file nor save and getting empty file and no result forward…
                                • G Offline
                                  ganther @Gailby
                                  @Gailby
                                  Yes. Just type these commands as given:
                                  touch ~/.vdirsyncer/config
                                  nano ~/.vdirsyncer/config
                                    schwoediauer @l0cal
                                    @l0cal Hi !
                                    I’m also interrested on this solution to display reminders on this way, but It dosen’t work actually for me.
                                    Do you have a running configuration
                                      maestro82
                                      Two run two calendars, would I need to adjust config.js file as well?
                                      • G Offline
                                        Gailby @Beh
                                        @Beh I had no problem adding several modules of same kind and several .ics files in Calendars…however it doesn’t seem to sync or retrieve anything…only says no upcomming events :/
                                        • G Offline
                                          ganther @Gailby
                                          @Gailby
                                          Is your ics-file in modules/calendars also 0kb?
                                          • G Offline
                                            Gailby @ganther
                                            @ganther I don’t know…I need to check
                                            • 8
                                            • 9
                                            • 2 / 9
