    No reading from DHT sensor
    7 Posts 2 Posters 3.7k Views 1 Watching
    • J
      Johans
      Re: MMM-DHT22 Humidity and Temperature Module
      installed modules as described in read.me file but I get no reading of temp or hum.
      sensor is working, tested with AdaFruit example
      • sudo ./AdafruitDHT.py 2302 27 (Data connected to gpio 27)
        I get a perfect temp & hum reading, so i’m shure sensor is working.
      i’m using an RPI3 - according to wiring pin, wpi 2 = gpio27 = physical pin 13.
      I think wiring is OK.
      anybody can help solving this.
      thx
      • J
        Johans
        nobody to help?
        • cowboysdudeC
          cowboysdude Module Developer
          Why aren’t you asking in the forum post for the module?
          https://forum.magicmirror.builders/topic/738/mmm-dht22-humidity-and-temperature-module
          • J
            Johans @cowboysdude
            @cowboysdude
            I did, but got message that topic where old and that is was better to create new topic - so i did.
            anyhow i’ll post it there as well
            cowboysdudeC 1 Reply Last reply Reply Quote 1
            • cowboysdudeC
              cowboysdude Module Developer @Johans
              @Johans Ok when you start MM what does the developers window say? Any errors?
              • J
                Johans @cowboysdude
                @cowboysdude
                nothing, all is perfect - no errors.
                yesterday tried every pin, nothing happens.
                Only module clock & this DHT22 module are in my config.
                Remover & reinstalled module.
                No luck .
                I thought sensor might be defect but I get a reading of temp & hum via the Adafruit DHT test program.
                I’ve seen other people have same problem - no reading. I’m wondering if they have sorted out or just gave up on this module.
                • cowboysdudeC
                  @Johans No sure… I don’t have a sensor or I’d be happy to test it out …
