    Tado module?
    35 Posts 5 Posters 30.4k Views 5 Watching
    • K Offline
      krisalexroberts
      There is a tado API, but I don’t know how to use this to display data on the MagicMirror
      https://my.tado.com/mobile/1.9/getCurrentState?username=xxxxxxxxxxxx@xxxxx.xxx&password=yyyyyyyyyyyyyyyyy
      I guess in its simplest form, we just need a module which connects to the above URL and then pulls information based on specific strings. eg: “insideTemp”:20.61
      I can do this in Python… not Javascript though
      Example of output
      {“success”:true,“operation”:“HOME”,“preheating”:false,“preheatingTargetOperation”:null,“autoOperation”:“HOME”,“operationTrigger”:“SYSTEM”,“insideTemp”:20.61,“setPointTemp”:20.8,“controlPhase”:“STEADY”,“currentUserPrivacyEnabled”:false,“currentUserGeoStale”:null,“deviceUpdating”:false,“homeId”:xxx,“heatingOn”:true,“internetGatewayType”:“GW02”,“internetGatewayConnected”:true,“heatingMuscleType”:“BU01”,“heatingMuscleConnected”:true,“insideTemperatureSensorType”:“RU01”,“insideTemperatureSensorConnected”:true,“settingsEnabled”:true,“fallbackOperation”:false,“helpUrl”:“https://support.tado.com/hc/","pendingDeviceInstallation”:false}
        dinkybluebug245
        I think the following variables would be quite useful.
        Insidetemp - displayed as a number
        setPointTemp - displayed as a number
        heatingon - displayed as an flame icon if set to true
        Maybe like this
        21.3° / 15.2° / 0_1479296200918_upload-f38c73ad-e4a6-4519-9068-47ca54312530
        Where the first temp in bold is current temp, the next is the trigger temperature (ie when the heating would come on) Would anyone else add anything different?
        Perhaps mode might be useful as well, as an icon which is held in variable autoOperation. I think the different options here are HOME, AWAY, MANUAL, and the other one for nighttime (not sure what this is called)
        • C Offline
          charliwest
          I tweaked the bash script to the api @krisalexroberts suggested as it takes a lot less to do it, and at @dinkybluebug245’s suggestion added the extra readings…although not sure how the pi will read the hex values? But it works on mac
          USERNAME=you@your.email
          PASSWORD=yourPassword
          curl --silent “https://my.tado.com/mobile/1.9/getCurrentState?username=“$USERNAME”&password=“$PASSWORD”” > temp
          insideTemp=$(grep -o “insideTemp." temp| awk ‘{print substr($1,13,4)}’)
          setPointTemp=$(grep -o "setPointTemp.
          ” temp| awk ‘{print substr($1,15,4)}’)
          heatingOn=$(if grep -q “"heatingOn":true” temp; then
          echo ‘\xf0\x9f\x94\xa5’
          else
          echo ‘\xf0\x9f\x9a\xab’
          fi)
          echo “$insideTemp” / “$setPointTemp” / “$heatingOn”
            dinkybluebug245 @charliwest
            @charliwest - so how does this all get written up as a magic mirror module? do you know?
            • C Offline
              charliwest
              Yeah no idea about nodejs stuff, spoke to a friend today who is hoping to build a magicmirror (I still havent had time to set mine up at all). He is keen to have a look at this with me. We will hopefully sit down over a couple of beers next week and see if we can bash something out.
              Anyone else who already knows more about modules happy for them to take the above and make it work…
              @dinkybluebug245 did you test the above, even though only a bash script, still pretty cool
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @charliwest
                @charliwest I would have some sparetime tonight, therefore I could help out if someone with a tado acc would like to join me
                • K Offline
                  krisalexroberts @strawberry 3.141
                  @strawberry-3.141 i have availability tonight
                    dinkybluebug245 @krisalexroberts
                    @strawberry-3-141 - Hello - I can help over the weekend, and next week - evenings this week Im busy
                      would be great to get someone with other devices than a heating unit
                      D K 2 Replies Last reply Reply Quote 0
                        dinkybluebug245 @strawberry 3.141
                        @strawberry-3.141 can’t help with that. But if you need some else to test tado heating api. I can help.
                        • 3 / 4
