    Tado module?
    35 Posts 5 Posters 30.6k Views 5 Watching
      dinkybluebug245 @charliwest
      This would be awesome!
        charliwest
        OK, well I have had a play and I can get this working via the API with curl commands…I guess its s start, then I looked at the module docs and woosh, it went right over my head. If it helps anyone here is the process for doing it in bash.
        ##Fill in your email and your password
        USERNAME=you@youremail.com
        PASSWORD=yourPassword
        ####You probably don’t want to edit below here####
        ##Grabs a cookie to stash your session details
        curl --silent “https://my.tado.com/j_spring_security_check?j_password=$PASSWORD&j_username=$USERNAME” --data-binary “{}” --cookie-jar /tmp/tadocookies
        ##Grabs your unique home ID from a bunch of info
        curl --silent “https://my.tado.com/api/v1/me” -H “Referer: https://my.tado.com/” --cookie /tmp/tadocookies > homeId
        HOMEID=$(grep -o “homeId.," homeId| awk -F, ‘{print $1}’|awk -F: ‘{print $2}’)
        ##Now uses your home ID to get the current temp of your home and displays it
        curl --silent “https://my.tado.com/api/v1/home/$HOMEID/hvacState” -H “Referer: https://my.tado.com/” --cookie /tmp/tadocookies > temp
        TEMP=$(grep -o "celsius.
        ,” temp| awk -F, ‘{print $1}’|awk -F: ‘{print $2}’)
        echo “$TEMP”
        If someone can use that to make an MMM pretty please ;)
        • K Offline
          krisalexroberts
          Has anyone been able to look at this yet?
          • K Offline
            krisalexroberts
            There is a tado API, but I don’t know how to use this to display data on the MagicMirror
            https://my.tado.com/mobile/1.9/getCurrentState?username=xxxxxxxxxxxx@xxxxx.xxx&password=yyyyyyyyyyyyyyyyy
            I guess in its simplest form, we just need a module which connects to the above URL and then pulls information based on specific strings. eg: “insideTemp”:20.61
            I can do this in Python… not Javascript though
            Example of output
            {“success”:true,“operation”:“HOME”,“preheating”:false,“preheatingTargetOperation”:null,“autoOperation”:“HOME”,“operationTrigger”:“SYSTEM”,“insideTemp”:20.61,“setPointTemp”:20.8,“controlPhase”:“STEADY”,“currentUserPrivacyEnabled”:false,“currentUserGeoStale”:null,“deviceUpdating”:false,“homeId”:xxx,“heatingOn”:true,“internetGatewayType”:“GW02”,“internetGatewayConnected”:true,“heatingMuscleType”:“BU01”,“heatingMuscleConnected”:true,“insideTemperatureSensorType”:“RU01”,“insideTemperatureSensorConnected”:true,“settingsEnabled”:true,“fallbackOperation”:false,“helpUrl”:“https://support.tado.com/hc/","pendingDeviceInstallation”:false}
              dinkybluebug245
              I think the following variables would be quite useful.
              Insidetemp - displayed as a number
              setPointTemp - displayed as a number
              heatingon - displayed as an flame icon if set to true
              Maybe like this
              21.3° / 15.2° / 0_1479296200918_upload-f38c73ad-e4a6-4519-9068-47ca54312530
              Where the first temp in bold is current temp, the next is the trigger temperature (ie when the heating would come on) Would anyone else add anything different?
              Perhaps mode might be useful as well, as an icon which is held in variable autoOperation. I think the different options here are HOME, AWAY, MANUAL, and the other one for nighttime (not sure what this is called)
                charliwest
                I tweaked the bash script to the api @krisalexroberts suggested as it takes a lot less to do it, and at @dinkybluebug245’s suggestion added the extra readings…although not sure how the pi will read the hex values? But it works on mac
                USERNAME=you@your.email
                curl --silent “https://my.tado.com/mobile/1.9/getCurrentState?username=“$USERNAME”&password=“$PASSWORD”” > temp
                insideTemp=$(grep -o “insideTemp." temp| awk ‘{print substr($1,13,4)}’)
                setPointTemp=$(grep -o "setPointTemp.
                ” temp| awk ‘{print substr($1,15,4)}’)
                heatingOn=$(if grep -q “"heatingOn":true” temp; then
                echo ‘\xf0\x9f\x94\xa5’
                else
                echo ‘\xf0\x9f\x9a\xab’
                fi)
                echo “$insideTemp” / “$setPointTemp” / “$heatingOn”
                  @charliwest - so how does this all get written up as a magic mirror module? do you know?
                    charliwest
                    Yeah no idea about nodejs stuff, spoke to a friend today who is hoping to build a magicmirror (I still havent had time to set mine up at all). He is keen to have a look at this with me. We will hopefully sit down over a couple of beers next week and see if we can bash something out.
                    Anyone else who already knows more about modules happy for them to take the above and make it work…
                    @dinkybluebug245 did you test the above, even though only a bash script, still pretty cool
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @charliwest
                      @charliwest I would have some sparetime tonight, therefore I could help out if someone with a tado acc would like to join me
                      • K Offline
                        krisalexroberts @strawberry 3.141
                        @strawberry-3.141 i have availability tonight
                        • 1 / 4
