    MMM-MyTraktSeries
    12 Posts 7 Posters 8.5k Views 7 Watching
    • T Offline
      TheVieiraAkA
      Trakt.tv-Module for the MagicMirror
      _This was inspired by MMM-Trakt github.com/Kiina/MMM-trakt, i just upgraded for my personal use, all credits to him
      LINK TO GITHUB
      MMM-MyTraktSeries
      Preview
      preview
      Todo
      • Pictures for the shows
      • More configuration options
      Creating a Trakt.tv API application
      To get your API keys you need to first create an Application. Give it a name, and enter http://localhost/ in the Redirect uri: field and and Javascript (cors) origins: (it’s a required field but not used for our purpose).
      Installation
      Clone the repository into your MagicMirror’s modules folder, and install dependencies:
        cd ~/MagicMirror/modules
        git clone https://github.com/TheVieiraAkA/MMM-MyTraktSeries
        cd MMM-MyTraktSeries
        npm install
      Using the Module
      To run the module, you need to add the following data to your ~/MagicMirror/config/config.js file:
          module: "MMM-MyTraktSeries",
          position: "top_left",           // Configurable
          header: "Trakt - Series",       // Configurable
                  client_id: "private_id",
                  client_secret: "secret_id",
                  username: 'username',
                  id_lista: "idlist",     // Example: "1234567"
                  type: "shows"
      Configuration
      Option Description
      id_lista To get the id_list you need to go to This Link, using the username in the URI Parameters and client_id in the Headers, and in the Response, search for the List “ids” and then “trakt” value.
        @TheVieiraAkA I’m trying out your module now, and I have set up application, API key + secret and list id. But I get this text on my mirror:
        Please enter the following on https://trakt.tv/activate: undefined
        It should be an 8 digit code. Any idea what is wrong?
        • T Offline
          TheVieiraAkA
          @retroflex That problem must be that some of your inputs are wrong, or you have a token file existing in the module file that is not valid anymore, if you have one delete it and try again
            retroflex Project Sponsor Module Developer @TheVieiraAkA
            @TheVieiraAkA Thanks! I have checked client_id, client_secret, username and id_lista and they are correct. And there is no token file from before.
            I get this exception in .pm2/logs/mm-error-0.log:
            TypeError: Error processing argument at index 1, conversion failure from 80
                at TypeError (native)
                at ClientRequest.setHeader (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:252:21)
                at ClientRequest (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:190:14)
                at Net.request (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:354:10)
                at get (/home/pi/MagicMirror/modules/MMM-MyTraktSeries/node_modules/got/index.js:49:18)
                at Immediate.setImmediate (/home/pi/MagicMirror/modules/MMM-MyTraktSeries/node_modules/got/index.js:124:3)
                at runCallback (timers.js:574:20)
                at tryOnImmediate (timers.js:554:5)
                at processImmediate [as _immediateCallback] (timers.js:533:5)
            • T Offline
              TheVieiraAkA @retroflex
              @retroflex hum… thats weird, I don’t know if this matter but try to put your Trakt account and custom List public and see if you get anything different. Plz let me know
                @TheVieiraAkA My trakt account was already public. But I found that I was using the default watchlist, which probably wasn’t a good idea. I created a new public list and switched the ID in the config to that one. Still no luck, same error.
                • T Offline
                  @retroflex Sorry about the delay
                  I recently update the module to fix some errors
                  make sure you delete the token.js file in the module, and you have the node_modules installed in my module
                  create an app on trakt.tv in here , and assign http://localhost/ to the “Redirect uri:” and “Javascript (cors) origins:”
                  Then before you try directlly on the module in the Magic Mirror, use the Trakt API to test it
                  1. go Here, and on URI Params, insert your username, and on Headers, put your Client_ID on trakt-api-key option and click Call Resource
                    1.1 it should give you a full list of custom lists that you have, search for :
                  “ids”: {
                  “trakt”: 123456,
                  “slug”: “asdvgasvdhasbdabsd”
                  1. on the config.js on Magic mirror, in the MMM-MyTraktSeries module, put the “123456” code that you got from the TraktAPI in the step 1 in the id_lista: field
                    it should work without a problem
                  luisestradaL 1 Reply Last reply Reply Quote 0
                    ankurchauhin
                    The above module you’ve mentioned above was in a very smooth way and i can able to set up an application, API key + secret and list id. But I get an error with the pop up “enter the following on our official website”! there we can use only the eight digit code and i tried one of my trakt friends suggestion and it worked me a lot, if any one get an error like me you can solve that issue from here.
                      dxfan227
                      what;s the user name?
                      • luisestradaL Offline
                        luisestrada @TheVieiraAkA
                        @TheVieiraAkA Hello,
                        I can’t understand why I use one list and it works but then I select another list and it doesn’t. I made it public, friends, private and nothing works.
                        It looks that this module was abandoned, but still works.
                        Thank you !!!
                          luisestrada @luisestrada
                          MMM-MyTraktSeries.js:61
                          Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘nextEp’)
                          at Class.getDom (MMM-MyTraktSeries.js:61:45)
                          at main.js:113:35
                          at new Promise ()
                          at updateDom (main.js:111:10)
                          at Object.updateDom (main.js:552:4)
                          at Class.updateDom (module.js:358:6)
                          at Class.socketNotificationReceived (MMM-MyTraktSeries.js:101:18)
                          at module.js:245:9
                          at Socket. (socketclient.js:38:4)
                          at Emitter.emit (index.mjs:136:20)
                          Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'nextEp')
                          Row 61 says:
                          title = this.shorten(aux[i].nextEp, 19);
                            sdetweil @luisestrada
                            @luisestrada means aux[i]
                            doesn’t point to an object.
