MMM-MyTraktSeries
Trakt.tv-Module for the MagicMirror
_This was inspired by MMM-Trakt github.com/Kiina/MMM-trakt, i just upgraded for my personal use, all credits to him
LINK TO GITHUB
Preview
Todo
- Pictures for the shows
- More configuration options
Creating a Trakt.tv API application
To get your API keys you need to first create an Application. Give it a name, and enter
http://localhost/in theRedirect uri:field and andJavascript (cors) origins:(it’s a required field but not used for our purpose).Installation
Clone the repository into your MagicMirror’s modules folder, and install dependencies:
cd ~/MagicMirror/modules git clone https://github.com/TheVieiraAkA/MMM-MyTraktSeries cd MMM-MyTraktSeries npm installUsing the Module
To run the module, you need to add the following data to your
~/MagicMirror/config/config.jsfile:{ module: "MMM-MyTraktSeries", position: "top_left", // Configurable header: "Trakt - Series", // Configurable config: { client_id: "private_id", client_secret: "secret_id", username: 'username', id_lista: "idlist", // Example: "1234567" type: "shows" } },Configuration
Option Description id_listaTo get the id_list you need to go to This Link, using the username in the URI Parametersand client_id in theHeaders, and in the Response, search for the List “ids” and then “trakt” value. -
@TheVieiraAkA I’m trying out your module now, and I have set up application, API key + secret and list id. But I get this text on my mirror:
Please enter the following on https://trakt.tv/activate: undefinedIt should be an 8 digit code. Any idea what is wrong?
@retroflex That problem must be that some of your inputs are wrong, or you have a token file existing in the module file that is not valid anymore, if you have one delete it and try again
@TheVieiraAkA Thanks! I have checked client_id, client_secret, username and id_lista and they are correct. And there is no token file from before.
I get this exception in .pm2/logs/mm-error-0.log:
TypeError: Error processing argument at index 1, conversion failure from 80 at TypeError (native) at ClientRequest.setHeader (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:252:21) at ClientRequest (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:190:14) at Net.request (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:354:10) at get (/home/pi/MagicMirror/modules/MMM-MyTraktSeries/node_modules/got/index.js:49:18) at Immediate.setImmediate (/home/pi/MagicMirror/modules/MMM-MyTraktSeries/node_modules/got/index.js:124:3) at runCallback (timers.js:574:20) at tryOnImmediate (timers.js:554:5) at processImmediate [as _immediateCallback] (timers.js:533:5) -
@retroflex hum… thats weird, I don’t know if this matter but try to put your Trakt account and custom List
publicand see if you get anything different. Plz let me know -
@TheVieiraAkA My trakt account was already public. But I found that I was using the default watchlist, which probably wasn’t a good idea. I created a new public list and switched the ID in the config to that one. Still no luck, same error.
@retroflex Sorry about the delay
I recently update the module to fix some errors
make sure you delete the token.js file in the module, and you have the node_modules installed in my module
create an app on trakt.tv in here , and assign http://localhost/ to the “Redirect uri:” and “Javascript (cors) origins:”
Then before you try directlly on the module in the Magic Mirror, use the Trakt API to test it- go Here, and on URI Params, insert your username, and on Headers, put your Client_ID on trakt-api-key option and click Call Resource
1.1 it should give you a full list of custom lists that you have, search for :
“ids”: {
“trakt”: 123456,
“slug”: “asdvgasvdhasbdabsd”
},- on the config.js on Magic mirror, in the MMM-MyTraktSeries module, put the “123456” code that you got from the TraktAPI in the step 1 in the id_lista: field
it should work without a problem
The above module you’ve mentioned above was in a very smooth way and i can able to set up an application, API key + secret and list id. But I get an error with the pop up “enter the following on our official website”! there we can use only the eight digit code and i tried one of my trakt friends suggestion and it worked me a lot, if any one get an error like me you can solve that issue from here.
what;s the user name?
@TheVieiraAkA Hello,
I can’t understand why I use one list and it works but then I select another list and it doesn’t. I made it public, friends, private and nothing works.
It looks that this module was abandoned, but still works.
Thank you !!!
MMM-MyTraktSeries.js:61
Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘nextEp’)
at Class.getDom (MMM-MyTraktSeries.js:61:45)
at main.js:113:35
at new Promise ()
at updateDom (main.js:111:10)
at Object.updateDom (main.js:552:4)
at Class.updateDom (module.js:358:6)
at Class.socketNotificationReceived (MMM-MyTraktSeries.js:101:18)
at module.js:245:9
at Socket. (socketclient.js:38:4)
at Emitter.emit (index.mjs:136:20)Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'nextEp')Row 61 says:
title = this.shorten(aux[i].nextEp, 19); -
@luisestrada means aux[i]
doesn’t point to an object.
