    MMM-MyTraktSeries
    12 Posts 7 Posters 8.7k Views 7 Watching
    • T Offline
      TheVieiraAkA
      @retroflex That problem must be that some of your inputs are wrong, or you have a token file existing in the module file that is not valid anymore, if you have one delete it and try again
        retroflex Project Sponsor Module Developer @TheVieiraAkA
        @TheVieiraAkA Thanks! I have checked client_id, client_secret, username and id_lista and they are correct. And there is no token file from before.
        I get this exception in .pm2/logs/mm-error-0.log:
        TypeError: Error processing argument at index 1, conversion failure from 80
            at TypeError (native)
            at ClientRequest.setHeader (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:252:21)
            at ClientRequest (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:190:14)
            at Net.request (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/browser/api/net.js:354:10)
            at get (/home/pi/MagicMirror/modules/MMM-MyTraktSeries/node_modules/got/index.js:49:18)
            at Immediate.setImmediate (/home/pi/MagicMirror/modules/MMM-MyTraktSeries/node_modules/got/index.js:124:3)
            at runCallback (timers.js:574:20)
            at tryOnImmediate (timers.js:554:5)
            at processImmediate [as _immediateCallback] (timers.js:533:5)
        • T Offline
          TheVieiraAkA @retroflex
          @retroflex hum… thats weird, I don’t know if this matter but try to put your Trakt account and custom List public and see if you get anything different. Plz let me know
            @TheVieiraAkA My trakt account was already public. But I found that I was using the default watchlist, which probably wasn’t a good idea. I created a new public list and switched the ID in the config to that one. Still no luck, same error.
            • T Offline
              @retroflex Sorry about the delay
              I recently update the module to fix some errors
              make sure you delete the token.js file in the module, and you have the node_modules installed in my module
              create an app on trakt.tv in here , and assign http://localhost/ to the “Redirect uri:” and “Javascript (cors) origins:”
              Then before you try directlly on the module in the Magic Mirror, use the Trakt API to test it
              1. go Here, and on URI Params, insert your username, and on Headers, put your Client_ID on trakt-api-key option and click Call Resource
                1.1 it should give you a full list of custom lists that you have, search for :
              “ids”: {
              “trakt”: 123456,
              “slug”: “asdvgasvdhasbdabsd”
              1. on the config.js on Magic mirror, in the MMM-MyTraktSeries module, put the “123456” code that you got from the TraktAPI in the step 1 in the id_lista: field
                it should work without a problem
              luisestradaL 1 Reply Last reply Reply Quote 0
                ankurchauhin
                The above module you’ve mentioned above was in a very smooth way and i can able to set up an application, API key + secret and list id. But I get an error with the pop up “enter the following on our official website”! there we can use only the eight digit code and i tried one of my trakt friends suggestion and it worked me a lot, if any one get an error like me you can solve that issue from here.
                  dxfan227
                  what;s the user name?
                  • luisestradaL Offline
                    luisestrada @TheVieiraAkA
                    @TheVieiraAkA Hello,
                    I can’t understand why I use one list and it works but then I select another list and it doesn’t. I made it public, friends, private and nothing works.
                    It looks that this module was abandoned, but still works.
                    Thank you !!!
                      luisestrada @luisestrada
                      MMM-MyTraktSeries.js:61
                      Uncaught (in promise) TypeError: Cannot read properties of undefined (reading ‘nextEp’)
                      at Class.getDom (MMM-MyTraktSeries.js:61:45)
                      at main.js:113:35
                      at new Promise ()
                      at updateDom (main.js:111:10)
                      at Object.updateDom (main.js:552:4)
                      at Class.updateDom (module.js:358:6)
                      at Class.socketNotificationReceived (MMM-MyTraktSeries.js:101:18)
                      at module.js:245:9
                      at Socket. (socketclient.js:38:4)
                      at Emitter.emit (index.mjs:136:20)
                      Uncaught (in promise) TypeError: Cannot read properties of undefined (reading 'nextEp')
                      Row 61 says:
                      title = this.shorten(aux[i].nextEp, 19);
                        sdetweil @luisestrada
                        @luisestrada means aux[i]
                        doesn’t point to an object.
