    cant get magicmirror to show up on screen
    pm2troubleshoot
    28 Posts 4 Posters 27.4k Views 5 Watching
    • K Offline
      kula
      Hi everyone,
      I have the same problem. Via ssh I get the same error. But using the same command in the terminal on the pi then it is working. I’m confused…
      • Y Offline
        yo-less Module Developer @kula
        @kula What command are you talking about?
        • K Offline
          kula @yo-less
          @yo-less sorry, npm start
          • Y Offline
            Then you’re not experiencing the same problem. What you are describing is normal behavior.
            If you use SSH, the Pi doesn’t know what monitor it should use, since you’re sitting in front of another monitor, so your command should be:
            DISPLAY=:0 npm start
            Try that, it should work without problems.
            Everything is also explained here .
            Why aren’t you using PM2 to run the mirror?
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              kula @yo-less
              @yo-less thanks, it works. I’m just getting into it and followed up the tutorial strawberry 3.141 mentioned before - with the difference that I used ssh :)
              now I’m going to read about the PM2 thing.
              • Y Offline
                @kula Great to know it’s working for you. Use PM2, it makes sure your mirror stays up and running and doesn’t stop at some stage. It also provides logs that can help troubleshoot potential mirror problems.
                • L Offline
                  lysnikolaou
                  It finally worked for me, after reinstalling raspbian. Thanks you everyone for your help!
                  • Y Offline
                    yo-less Module Developer @lysnikolaou
                    @lysnikolaou Welcome to the world of MagicMirror² :)
