    cant get magicmirror to show up on screen
    pm2troubleshoot
    28 Posts 4 Posters 27.7k Views 5 Watching
    • Y
      yo-less Module Developer
      Hm, like I said, anything I’m suggesting at this stage is purely experimental as I have no experience with setting up the MagicMirror electron environment, but you could try upgrading your node installation.
      Please only do that if you are willing to set up your Pi all over again (Reinstalling Raspbian, etc.) should this fail, because it’s hardly ever a good idea to turn your system into a patchwork project.
      Someone at stackexchange.com said this helped them in installing Node.js on their Pi 3:
      curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
      sudo apt-get install -y nodejs
      sudo apt-get install -y build-essential
      Source: http://raspberrypi.stackexchange.com/questions/45319/install-newer-node-version-on-pi-3
      If you’re not willing to reinstall everything, should this compromise your Raspbian setup, I would suggest waiting for other forum members’ suggestions on how to proceed.
      • L
        lysnikolaou
        I had done just that, even before your post. And when i run nodejs -v it outputs v6… which is just fine. I don’t know, maybe I will reinstall raspbian and start it all over again
        • Y
          That might be the best way of going about it if you are only planning on using the Pi for the Magic Mirror.
          Did you start out with a brand new Pi or did you install some other software on it as well?
          • L
            lysnikolaou
            No, only this, but I first followed wrong instructions and installed unnecessary software that might have somehow affected the other installations.
            • Y
              Then do it again, since you’re only just starting, you will only lose an hour or so and hopefully end up with a working system. This way you can ensure you have a working mirror that is fun to configure. At this stage you’re having problems with it starting up, who knows what other problems might be lurking in the darker corners of your Raspbian installation. Just make sure you grab the latest Raspbian image when reinstalling.
              Let us know whether it worked the second time round.
              • L
                lysnikolaou
                I will certainly let you know. Do you think that it would be better to run the automatic installation command or manually install nodejs, clone the rep and the install npm?
                Y 1 Reply Last reply
                • strawberry 3.141S
                  i did it like this on several pi’s now and never had issues https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                  • Y
                    yo-less Module Developer @lysnikolaou
                    @lysnikolaou Unfortunately, I have no experience with the automatic installation because it isn’t supported for my hardware setup. But it seems to be the best way of going about it and the instructions in the link @strawberry-3-141 has posted is the way to go, @KirAsh4 has put a lot of energy into it and if you follow it closely, I’d be surprised if you still ran into trouble.
                    • L
                      lysnikolaou
                      Thanks a lot to both of you. I will inform you about the results, as soon as I have it done.
                      • K
                        kula
                        Hi everyone,
                        I have the same problem. Via ssh I get the same error. But using the same command in the terminal on the pi then it is working. I’m confused…
                        • Y
                          yo-less Module Developer @kula
                          @kula What command are you talking about?
                          K 1 Reply Last reply
                          • K
                            kula @yo-less
                            @yo-less sorry, npm start
                            • Y
                              Then you’re not experiencing the same problem. What you are describing is normal behavior.
                              If you use SSH, the Pi doesn’t know what monitor it should use, since you’re sitting in front of another monitor, so your command should be:
                              DISPLAY=:0 npm start
                              Try that, it should work without problems.
                              Everything is also explained here .
                              Why aren’t you using PM2 to run the mirror?
                              • K
                                kula @yo-less
                                @yo-less thanks, it works. I’m just getting into it and followed up the tutorial strawberry 3.141 mentioned before - with the difference that I used ssh :)
                                now I’m going to read about the PM2 thing.
                                • Y
                                  @kula Great to know it’s working for you. Use PM2, it makes sure your mirror stays up and running and doesn’t stop at some stage. It also provides logs that can help troubleshoot potential mirror problems.
                                  • L
                                    lysnikolaou
                                    It finally worked for me, after reinstalling raspbian. Thanks you everyone for your help!
                                    • Y
                                      @lysnikolaou Welcome to the world of MagicMirror² :)
