    cant get magicmirror to show up on screen
    pm2troubleshoot
    28 Posts 4 Posters 27.6k Views 5 Watching
    • L Offline
      lysnikolaou
      I get a whole bunch of errors, but the output tells me that I either have wrong versions of nodejs or npm or the magicmirror package itself is the one to blame. After that comes the message that electron js/electron.js fails
      Here is the log file that need to be submitted according to the log output:
      1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@3.10.3
      3 info using node@v6.5.0
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
      6 silly lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
      8 verbose lifecycle magicmirror@2.0.0~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.0.0~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      10 verbose lifecycle magicmirror@2.0.0~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.0.0~start: Args: [ ‘-c’, ‘electron js/electron.js’ ]
      12 info lifecycle magicmirror@2.0.0~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.0.0 start: electron js/electron.js
      13 verbose stack spawn ENOENT
      13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
      13 verbose stack at emitTwo (events.js:106:13)
      13 verbose stack at ChildProcess.emit (events.js:191:7)
      13 verbose stack at maybeClose (internal/child_process.js:877:16)
      13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      14 verbose pkgid magicmirror@2.0.0
      15 verbose cwd /home/pi/MagicMirror
      16 error Linux 4.4.13-v7+
      17 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
      18 error node v6.5.0
      19 error npm v3.10.3
      20 error file sh
      21 error code ELIFECYCLE
      22 error errno ENOENT
      23 error syscall spawn
      24 error magicmirror@2.0.0 start: electron js/electron.js
      24 error spawn ENOENT
      25 error Failed at the magicmirror@2.0.0 start script ‘electron js/electron.js’.
      25 error Make sure you have the latest version of node.js and npm installed.
      25 error If you do, this is most likely a problem with the magicmirror package,
      25 error not with npm itself.
      25 error Tell the author that this fails on your system:
      25 error electron js/electron.js
      25 error You can get information on how to open an issue for this project with:
      25 error npm bugs magicmirror
      25 error Or if that isn’t available, you can get their info via:
      25 error npm owner ls magicmirror
      25 error There is likely additional logging output above.
      26 verbose exit [ 1, true ]
      • Y Offline
        yo-less Module Developer
        Ok, there might be a problem with your electron installation.
        Can you go into your MagicMirror folder and type “node serveronly”?
        Then, go back to your browser window and type in “localhost:8080”
        • L Offline
          lysnikolaou
          Ok it is now working.
          I will now try to enable kioskmode.
          • Y Offline
            This would mean that there seems to be a problem with your electron installation. Since you’ve got a Pi 3, I would try to get that fixed, it’s much easier to have the mirror act the way you want it to if the kiosk mode comes up automatically. I’m running the mirror on a Pi 1 and it took me forever to get everything set up so that the system boots into the mirror, I had to make sure the browser didn’t start too early, and so on. It requires many manual modifications and I’m almost certain that’s not the path you want to take :).
            Your mirror installation is not properly set up, I would try to fix that.
            I’m not sure if the problem on your system is electron or the mirror installation, as I’m not able to use electron on my Pi I have no experience with using it. But you can try going to your MagicMirror folder and typing in: “npm install electron”, this may set things right.
            If it doesn’t, maybe try a reinstall.
            • L Offline
              lysnikolaou
              I get an error every time. Both with npm install electron and by reinstalling the whole package. I dont get what the error is but it seems to be with nodejs.
              • Y Offline
                Hm, like I said, anything I’m suggesting at this stage is purely experimental as I have no experience with setting up the MagicMirror electron environment, but you could try upgrading your node installation.
                Please only do that if you are willing to set up your Pi all over again (Reinstalling Raspbian, etc.) should this fail, because it’s hardly ever a good idea to turn your system into a patchwork project.
                Someone at stackexchange.com said this helped them in installing Node.js on their Pi 3:
                curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
                sudo apt-get install -y nodejs
                sudo apt-get install -y build-essential
                Source: http://raspberrypi.stackexchange.com/questions/45319/install-newer-node-version-on-pi-3
                If you’re not willing to reinstall everything, should this compromise your Raspbian setup, I would suggest waiting for other forum members’ suggestions on how to proceed.
                • L Offline
                  lysnikolaou
                  I had done just that, even before your post. And when i run nodejs -v it outputs v6… which is just fine. I don’t know, maybe I will reinstall raspbian and start it all over again
                  • Y Offline
                    That might be the best way of going about it if you are only planning on using the Pi for the Magic Mirror.
                    Did you start out with a brand new Pi or did you install some other software on it as well?
                    • L Offline
                      lysnikolaou
                      No, only this, but I first followed wrong instructions and installed unnecessary software that might have somehow affected the other installations.
                      • Y Offline
                        Then do it again, since you’re only just starting, you will only lose an hour or so and hopefully end up with a working system. This way you can ensure you have a working mirror that is fun to configure. At this stage you’re having problems with it starting up, who knows what other problems might be lurking in the darker corners of your Raspbian installation. Just make sure you grab the latest Raspbian image when reinstalling.
                        Let us know whether it worked the second time round.
                        • L Offline
                          lysnikolaou
                          I will certainly let you know. Do you think that it would be better to run the automatic installation command or manually install nodejs, clone the rep and the install npm?
                          • strawberry 3.141S Offline
                            i did it like this on several pi’s now and never had issues https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
                            • Y Offline
                              yo-less Module Developer @lysnikolaou
                              @lysnikolaou Unfortunately, I have no experience with the automatic installation because it isn’t supported for my hardware setup. But it seems to be the best way of going about it and the instructions in the link @strawberry-3-141 has posted is the way to go, @KirAsh4 has put a lot of energy into it and if you follow it closely, I’d be surprised if you still ran into trouble.
                              • L Offline
                                lysnikolaou
                                Thanks a lot to both of you. I will inform you about the results, as soon as I have it done.
                                • K Offline
                                  kula
                                  Hi everyone,
                                  I have the same problem. Via ssh I get the same error. But using the same command in the terminal on the pi then it is working. I’m confused…
                                  • Y Offline
                                    yo-less Module Developer @kula
                                    @kula What command are you talking about?
                                    • K Offline
                                      kula @yo-less
                                      @yo-less sorry, npm start
                                      • Y Offline
                                        Then you’re not experiencing the same problem. What you are describing is normal behavior.
                                        If you use SSH, the Pi doesn’t know what monitor it should use, since you’re sitting in front of another monitor, so your command should be:
                                        DISPLAY=:0 npm start
                                        Try that, it should work without problems.
                                        Everything is also explained here .
                                        Why aren’t you using PM2 to run the mirror?
                                        K 1 Reply Last reply Reply Quote 1
                                        • K Offline
                                          kula @yo-less
                                          @yo-less thanks, it works. I’m just getting into it and followed up the tutorial strawberry 3.141 mentioned before - with the difference that I used ssh :)
                                          now I’m going to read about the PM2 thing.
                                          • Y Offline
                                            @kula Great to know it’s working for you. Use PM2, it makes sure your mirror stays up and running and doesn’t stop at some stage. It also provides logs that can help troubleshoot potential mirror problems.
