    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 491.6k Views 48 Watching
      rakostamas
      Hey, I have just installed the module, but I realized one minor mistake. The distances in the table have too much numbers after the decimal point. Where can I change it to just one decimal number?
      • O Offline
        othomys
        Hello,
        I use the tankerkoenig-api to let me see the German fuel prices. Unfortunately, the special characters (ä, ö, ü, ß, …) are not displayed correctly. At which point can I adapt the encoding?
        Thank you in advance.
          dazza120
          Is there anyway to to get this for UK fuel prices?
          • strawberry 3.141S Offline
            @rakostamas I try to adjust it in the next update.
            @othomys I think that’s a problem with the nunjuck templates that I didn’T figure out yet.
            @dazza120 is there a public api for it?
            D R 2 Replies Last reply Reply Quote 0
              dazza120 @strawberry 3.141
              @strawberry-3-141 doesn’t look like the UK does have an api for fuel prices
                rakostamas @strawberry 3.141
                @strawberry-3-141
                I reinstalled the mirror and installed the module again, however it stopped working. (It’s shows only “loading”) I’m using the same config file as before. Every module beside this working :/ Is it possible, that there is a bug in the module?
                  strawberry 3.141 Project Sponsor Module Developer @rakostamas
                  @rakostamas which branch are you using? Develop or master? On develop I’m working on a refactoring, so bugs are definetly possible. Master was probably not changed in a year.
                  Any errors in the console?
                  Did you install the dependencies?
                  Can you post your confit part without the API key and a bit modified gps position?
                    @strawberry-3-141
                    here is my config:
                    			module: "MMM-Fuel",
                    				provider: "spritpreisrechner",
                    				lat: 47.041194,
                    				lng: 15.453377,
                    				types: ["e5", "diesel"],
                    				radius: 6,
                    				max: 4,
                    				sortBy: "e5",
                    				open: true,
                    The mirror only displays the header and loading…
                    I have installed it in the following way:
                      sdetweil @rakostamas
                      @rakostamas run
                      npm start dev
                      to open the development screen, select the console tab… are there any errors (in red) shown?
                        rakostamas @sdetweil
                        Yes it seems :D
                        • 9
                        • 10
                        • 11
                        • 12
                        • 13
                        • 17
                        • 18
                        • 11 / 18
