    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 581.6k Views 48 Watching
    • C
      codac
      With the new update of MM I’m getting the following error:
      0|mm       | [15.04.2021 14:11.21.945] [ERROR] (node:15096) UnhandledPromiseRejectionWarning: Error: Cannot find module 'geolib'
      0|mm       | Require stack:
      0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js
      0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js
      0|mm       | - /home/pi/MagicMirror/js/app.js
      0|mm       | - /home/pi/MagicMirror/js/electron.js
      0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
      • C
        Commander @strawberry 3.141
        @strawberry-3-141
        Hello, i want to check prices of only 3 specific gas stations, but it doesn`t work.
        code_text:
                       api_key: "XXXXXXXXXXXXX-XXX-XXXX-XXXXXXXXXXXX",
                       types: ["e5"],
               	       rotate: true,
               	       showDistance:false,
               	       lat: 50.8634,
                       lng: 8.03944,
                       stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d"],
                       radius: 0,
               	       lat: 50.8708534,
                       lng: 8.014519,
                       stationIds: ["1b41801e-ee5e-490e-86d6-474bafec5dc4"],
                       radius: 0,
               	       lat: 50.871715,
               	       lng: 8.012415,
                       stationIds: ["4b9763df-8cce-426f-a1d5-2b44d413550a"],
                       radius: 0,
                       // all your config options, which are different than their default values
        I try to set stationIds like that:
        stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a"],
        but it also doesn`t work.
        Could you explaine how set specific gas stations?
        JalibuJ 1 Reply Last reply Reply Quote 0
        • JalibuJ
          Jalibu Module Developer @Commander
          @commander said in MMM-Fuel:
          stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a”],
          try
          stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d", "1b41801e-ee5e-490e-86d6-474bafec5dc4", "4b9763df-8cce-426f-a1d5-2b44d413550a"],
          C 1 Reply Last reply Reply Quote 1
          • C
            Commander @Jalibu
            @jalibu said in MMM-Fuel:
            stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d”, “1b41801e-ee5e-490e-86d6-474bafec5dc4”, “4b9763df-8cce-426f-a1d5-2b44d413550a”],
            Oh yes tanks !
              Seansation
              Hello,
              is it possible to sort by distance without rotation?
              			module: "MMM-Fuel",
              				api_key: "my_key",
              				showAddress: false,
              				rotate: false,
              				lat: my_lat,
              				lng: my_lng,
              				shortenText: false,
              				types: ["e5"],
              				sortBy: "e5", //possible to sort by distance? e.g. sortBy: "distance"
              Thank you
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @Seansation
                @seansation this is currently not supported, feel free to send a pr.
                • strawberry 3.141S
                  Now also supporting fuel prices in the USA. Take a look at https://github.com/cowboysdude/MMM-Gas for different style of the same information.
                  2.3.0
                  MagicMirror² version >= 2.15.0 required.
                  Added
                  • Provider: autoblog
                  • Config option: showBrand
                  • Integrated MagicMirror logger on server side
                  • Dependency: node-html-parser
                  • Config option excludeStationIds to exclude gas stations from radius (Tankerkönig only)
                  Changed
                  • Updated Github config files
                  • Updated dependencies
                  Removed
                  • Dependency: fs-extra
                  • Dependency: geolib
                  Link to module https://github.com/fewieden/MMM-Fuel
                  cowboysdudeC 1 Reply Last reply Reply Quote 2
                  • strawberry 3.141S
                    Fixed
                    • Tankerkoenig prices for requests with stationIds
                    • JerryPJ
                      JerryP
                      Is this also running for the Dutch petrol prices???
                      • R
                        Ray
                        This is a great app. Good job well done
                        is there a way to add a favorite gas station
                        or make it a future project
                        I’m in the United States so I’m using that configuration
                        • cowboysdudeC
                          cowboysdude Module Developer @strawberry 3.141
                          @strawberry-3-141 Looks great!
                          • strawberry 3.141S
                            @JerryP currently only Germany, Austria, USA and parts of Australia are covered by the module. If you find an API for fuel prices in the Netherlands I’m happy to integrate it. Please create an issue for the Github repository so it doesn’t get lost https://github.com/fewieden/MMM-Fuel/issues
                            @Ray currently it is only possible for Germany to select specific gas stations. The source for the USA doesn’t provide IDs that you can request for. Please create an issue for the Github repository so we can discuss some posibilities https://github.com/fewieden/MMM-Fuel/issues
                            • N
                              NSpr
                              Would the below API provide support for the UK and more in one?
                              https://developer.here.com/documentation/fuel-prices/dev_guide/topics/example-fuel-price.html
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @NSpr
                                @NSpr I was looking into the here API before since it would cover multiple countries at once, but sadly Note: Please note that the Fuel Prices service is only available to automotive OEMs for in-vehicle applications.
                                • strawberry 3.141S
                                  Alternative provider for the USA and also supporting Canada and Tasmania (Australia) now.
                                  2.4.0
                                  Added
                                  • Provider: gasbuddy
                                  • Config option: fade
                                  • Config option: showAddressCity
                                  Changed
                                  • Migrated provider nsw from API v1 to v2 in order to support new region Tasmania (Australia)
                                  • Dependency update
                                  • M
                                    MisterT @strawberry 3.141
                                    Hi @strawberry-3-141 i’m french and the data for the price of fuel is “opensource”. That’s why you can obtain informations about fuel, price fuel and type of fuel, fuel location, etc…
                                    these informations are update every day
                                    If you follow these links below, you can find exemple to use data :
                                    https://www.data.economie.gouv.fr/explore/dataset/prix-carburants-fichier-quotidien-test-ods/api/(link url)
                                    there are different tabs to navigate between graph, informations and locations
                                    https://www.data.economie.gouv.fr/api/v2/console(link url)
                                    this is the API (i think) to use data
                                    I don’t know if it’s possible to integrate french fuel data in your module or it’s too complicated because i’m a noob in programmation/coding.
                                    Maybe you can check these informations and tell me if possible?
                                    and sorry for my english :-)
                                    Thx
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @MisterT
                                      @MisterT I don’t see why it should not be possible. Please create a feature request in the GitHub repository https://github.com/fewieden/MMM-Fuel/issues
                                      • strawberry 3.141S
                                        Thanks to marcx28 for their contributions.
                                        Fixed
                                        • Sorting by price
                                        Added
                                        • Dependency: lodash
                                        Changed
                                        • Allow custom header text
                                        • 6
                                        • 7
                                        • 8
                                        • 9
                                        • 9 / 9
