    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.6k Views 48 Watching
    • strawberry 3.141S
      @RIKKO14 currently this module only supports Germany, Austria and NSW in Australia.
      If you find an API for data in France the module can be expanded. A guide can be found here.
      @eniac there are a couple of issues.
      1. You have the wrong format for the stationIds. It should be stationIds: ["9ac83212-c785-476f-9862-34a4b04f6320"].
      2. I suggest not going lower than the default update interval of 15min. You currently fetch data every minute, which can lead to a suspension of your API key as other users experienced before. Also see limitations here https://creativecommons.tankerkoenig.de/terms
      3. The fuel type should be lowercase
      4. The fuel station id you tried is inside the default search radius. There seems to be a bug currently, where we still make a request even if the list is empty. I suggest to either disable the radius search or remove the station ids.
        module: "MMM-Fuel",
          api_key: "XXXXXXXXXXXX",
          lat: 50.873798,
          lng: 8.023410,
          types: ["e5"],
          stationIds: ["9ac83212-c785-476f-9862-34a4b04f6320"],
          radius: 0
        module: "MMM-Fuel",
          lat: 50.873798,
          lng: 8.023410,
          types: ["e5"]
      C 1 Reply Last reply
      • strawberry 3.141S
        Version 2.2.1
        Fixed
        • Filtering of station ids lead to invalid price request for provider tankerkoenig
        Changed
        • Log a warning if no fuel station detail could be fetched
        • Updated provider integration documentation
        https://github.com/fewieden/MMM-Fuel
        [card: fewieden/MMM-Fuel]
          codac
          With the new update of MM I’m getting the following error:
          0|mm       | [15.04.2021 14:11.21.945] [ERROR] (node:15096) UnhandledPromiseRejectionWarning: Error: Cannot find module 'geolib'
          0|mm       | Require stack:
          0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js
          0|mm       | - /home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js
          0|mm       | - /home/pi/MagicMirror/js/app.js
          0|mm       | - /home/pi/MagicMirror/js/electron.js
          0|mm       | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
            Commander @strawberry 3.141
            @strawberry-3-141
            Hello, i want to check prices of only 3 specific gas stations, but it doesn`t work.
            code_text:
                           api_key: "XXXXXXXXXXXXX-XXX-XXXX-XXXXXXXXXXXX",
                           types: ["e5"],
                   	       rotate: true,
                   	       showDistance:false,
                   	       lat: 50.8634,
                           lng: 8.03944,
                           stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d"],
                           radius: 0,
                   	       lat: 50.8708534,
                           lng: 8.014519,
                           stationIds: ["1b41801e-ee5e-490e-86d6-474bafec5dc4"],
                           radius: 0,
                   	       lat: 50.871715,
                   	       lng: 8.012415,
                           stationIds: ["4b9763df-8cce-426f-a1d5-2b44d413550a"],
                           radius: 0,
                           // all your config options, which are different than their default values
            I try to set stationIds like that:
            stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a"],
            but it also doesn`t work.
            Could you explaine how set specific gas stations?
            JalibuJ 1 Reply Last reply
            • JalibuJ
              Jalibu Module Developer @Commander
              @commander said in MMM-Fuel:
              stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a”],
              try
              stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d", "1b41801e-ee5e-490e-86d6-474bafec5dc4", "4b9763df-8cce-426f-a1d5-2b44d413550a"],
                Commander @Jalibu
                @jalibu said in MMM-Fuel:
                stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d”, “1b41801e-ee5e-490e-86d6-474bafec5dc4”, “4b9763df-8cce-426f-a1d5-2b44d413550a”],
                Oh yes tanks !
                  Seansation
                  is it possible to sort by distance without rotation?
                  			module: "MMM-Fuel",
                  				api_key: "my_key",
                  				showAddress: false,
                  				rotate: false,
                  				lat: my_lat,
                  				lng: my_lng,
                  				shortenText: false,
                  				types: ["e5"],
                  				sortBy: "e5", //possible to sort by distance? e.g. sortBy: "distance"
                  Thank you
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @Seansation
                    @seansation this is currently not supported, feel free to send a pr.
                    • strawberry 3.141S
                      Now also supporting fuel prices in the USA. Take a look at https://github.com/cowboysdude/MMM-Gas for different style of the same information.
                      2.3.0
                      MagicMirror² version >= 2.15.0 required.
                      Added
                      • Provider: autoblog
                      • Config option: showBrand
                      • Integrated MagicMirror logger on server side
                      • Dependency: node-html-parser
                      • Config option excludeStationIds to exclude gas stations from radius (Tankerkönig only)
                      Changed
                      • Updated Github config files
                      • Updated dependencies
                      Removed
                      • Dependency: fs-extra
                      • Dependency: geolib
                      Link to module https://github.com/fewieden/MMM-Fuel
                      Reply Quote 2
                      • strawberry 3.141S
                        Fixed
                        • Tankerkoenig prices for requests with stationIds
                        • JerryPJ
                          JerryP
                          Is this also running for the Dutch petrol prices???
                            Ray
                            This is a great app. Good job well done
                            is there a way to add a favorite gas station
                            or make it a future project
                            I’m in the United States so I’m using that configuration
                            • cowboysdudeC
                              cowboysdude Module Developer @strawberry 3.141
                              @strawberry-3-141 Looks great!
                              • strawberry 3.141S
                                @JerryP currently only Germany, Austria, USA and parts of Australia are covered by the module. If you find an API for fuel prices in the Netherlands I’m happy to integrate it. Please create an issue for the Github repository so it doesn’t get lost https://github.com/fewieden/MMM-Fuel/issues
                                @Ray currently it is only possible for Germany to select specific gas stations. The source for the USA doesn’t provide IDs that you can request for. Please create an issue for the Github repository so we can discuss some posibilities https://github.com/fewieden/MMM-Fuel/issues
                                • N
                                  NSpr
                                  Would the below API provide support for the UK and more in one?
                                  https://developer.here.com/documentation/fuel-prices/dev_guide/topics/example-fuel-price.html
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @NSpr
                                    @NSpr I was looking into the here API before since it would cover multiple countries at once, but sadly Note: Please note that the Fuel Prices service is only available to automotive OEMs for in-vehicle applications.
                                    • strawberry 3.141S
                                      Alternative provider for the USA and also supporting Canada and Tasmania (Australia) now.
                                      2.4.0
                                      Added
                                      • Provider: gasbuddy
                                      • Config option: fade
                                      • Config option: showAddressCity
                                      Changed
                                      • Migrated provider nsw from API v1 to v2 in order to support new region Tasmania (Australia)
                                      • Dependency update
                                      M 1 Reply Last reply
                                        MisterT @strawberry 3.141
                                        Hi @strawberry-3-141 i’m french and the data for the price of fuel is “opensource”. That’s why you can obtain informations about fuel, price fuel and type of fuel, fuel location, etc…
                                        these informations are update every day
                                        If you follow these links below, you can find exemple to use data :
                                        https://www.data.economie.gouv.fr/explore/dataset/prix-carburants-fichier-quotidien-test-ods/api/(link url)
                                        there are different tabs to navigate between graph, informations and locations
                                        https://www.data.economie.gouv.fr/api/v2/console(link url)
                                        this is the API (i think) to use data
                                        I don’t know if it’s possible to integrate french fuel data in your module or it’s too complicated because i’m a noob in programmation/coding.
                                        Maybe you can check these informations and tell me if possible?
                                        and sorry for my english :-)
                                        Thx
                                        • strawberry 3.141S
                                          strawberry 3.141 Project Sponsor Module Developer @MisterT
                                          @MisterT I don’t see why it should not be possible. Please create a feature request in the GitHub repository https://github.com/fewieden/MMM-Fuel/issues
                                          • strawberry 3.141S
                                            Thanks to marcx28 for their contributions.
                                            Fixed
                                            • Sorting by price
                                            Added
                                            • Dependency: lodash
                                            Changed
                                            • Allow custom header text
                                            • 9 / 9
