@Pielo the documentation states that you need to provide an integer of how many character you want to see, the value false is just to deactivate the behavior.
Option Default Description shortenText false Integer of characters to be shown for name and address. Default shows all.If you do
shortenText: 5, then it will show 5 characters andshortenText: 10will show 10 and so on -
Version 2.1.2
Added
- Config option
showDistancehttps://github.com/fewieden/MMM-Fuel/pull/49 - Missing jsdoc documentation
Changed
- Dependency update
Fixed
- Deinit map had a hardcoded index for markers.
[card:fewieden/MMM-Fuel]
- Config option
Version 2.2.0
Thanks to @TheDuffman85 for his contribution to this release. This version allows either to search by radius, specific station, or a combination of those two for provider Tankerkönig (Germany).
Added
- Config option
stationIdsto check prices of specific gas stations (Tankerkönig only) - Github actions
Changed
- 3rd decimal is now superscripted
- Price and distance values are now localized based on global config option
locale.
Removed
- Travis-CI integration
[card: fewieden/MMM-Fuel]
- Config option
Does this module work for France? -
Hello … getting this Error with npm start DEV
[17:08:01.452] [LOG] Error: Error no fuel station detail
at setStationInfos (/home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js:189:19)
at process._tickCallback (internal/process/next_tick.js:68:7)module: "MMM-Fuel", position: "top_right", config: { //provider: "tankerkoenig", api_key: "xxxxxxxxxxxxxxxxxxxxxx", lat: 50.873798, lng: 8.023410, types: ["E5"], updateInterval: 60000, stationIds: [ { "id": "9ac83212-c785-476f-9862-34a4b04f6320", "name": "BELL Oil", ......................................What could that be ?
@RIKKO14 currently this module only supports Germany, Austria and NSW in Australia.
If you find an API for data in France the module can be expanded. A guide can be found here.
@eniac there are a couple of issues.
- You have the wrong format for the stationIds. It should be
stationIds: ["9ac83212-c785-476f-9862-34a4b04f6320"]. - I suggest not going lower than the default update interval of 15min. You currently fetch data every minute, which can lead to a suspension of your API key as other users experienced before. Also see limitations here https://creativecommons.tankerkoenig.de/terms
- The fuel type should be lowercase
- The fuel station id you tried is inside the default search radius. There seems to be a bug currently, where we still make a request even if the list is empty. I suggest to either disable the radius search or remove the station ids.
{ module: "MMM-Fuel", position: "top_right", config: { api_key: "XXXXXXXXXXXX", lat: 50.873798, lng: 8.023410, types: ["e5"], stationIds: ["9ac83212-c785-476f-9862-34a4b04f6320"], radius: 0 } },{ module: "MMM-Fuel", position: "top_right", config: { api_key: "XXXXXXXXXXXX", lat: 50.873798, lng: 8.023410, types: ["e5"] } },
Version 2.2.1
Fixed
- Filtering of station ids lead to invalid price request for provider tankerkoenig
Changed
- Log a warning if no fuel station detail could be fetched
- Updated provider integration documentation
With the new update of MM I’m getting the following error:
0|mm | [15.04.2021 14:11.21.945] [ERROR] (node:15096) UnhandledPromiseRejectionWarning: Error: Cannot find module 'geolib' 0|mm | Require stack: 0|mm | - /home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js 0|mm | - /home/pi/MagicMirror/modules/MMM-Fuel/node_helper.js 0|mm | - /home/pi/MagicMirror/js/app.js 0|mm | - /home/pi/MagicMirror/js/electron.js 0|mm | - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js -
@strawberry-3-141
Hello, i want to check prices of only 3 specific gas stations, but it doesn`t work.code_text: config: { api_key: "XXXXXXXXXXXXX-XXX-XXXX-XXXXXXXXXXXX", types: ["e5"], rotate: true, showDistance:false, lat: 50.8634, lng: 8.03944, stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d"], radius: 0, lat: 50.8708534, lng: 8.014519, stationIds: ["1b41801e-ee5e-490e-86d6-474bafec5dc4"], radius: 0, lat: 50.871715, lng: 8.012415, stationIds: ["4b9763df-8cce-426f-a1d5-2b44d413550a"], radius: 0, // all your config options, which are different than their default values }I try to set stationIds like that:
stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a"],but it also doesn`t work.
Could you explaine how set specific gas stations?Thanks
@commander said in MMM-Fuel:
stationIds: [“238715f9-60d6-4f7a-9e74-c40fdb71a79d,1b41801e-ee5e-490e-86d6-474bafec5dc4,4b9763df-8cce-426f-a1d5-2b44d413550a”],
try
stationIds: ["238715f9-60d6-4f7a-9e74-c40fdb71a79d", "1b41801e-ee5e-490e-86d6-474bafec5dc4", "4b9763df-8cce-426f-a1d5-2b44d413550a"], -
is it possible to sort by distance without rotation?
{ module: "MMM-Fuel", position: "top_right", config: { api_key: "my_key", showAddress: false, rotate: false, lat: my_lat, lng: my_lng, shortenText: false, types: ["e5"], sortBy: "e5", //possible to sort by distance? e.g. sortBy: "distance" }Thank you
@seansation this is currently not supported, feel free to send a pr.
Now also supporting fuel prices in the USA. Take a look at https://github.com/cowboysdude/MMM-Gas for different style of the same information.
2.3.0
MagicMirror² version >= 2.15.0 required.
Added
- Provider:
autoblog - Config option:
showBrand - Integrated MagicMirror logger on server side
- Dependency:
node-html-parser - Config option
excludeStationIdsto exclude gas stations from radius (Tankerkönig only)
Changed
- Updated Github config files
- Updated dependencies
Removed
- Dependency:
fs-extra - Dependency:
geolib
Link to module https://github.com/fewieden/MMM-Fuel
- Provider:
2.3.1
Fixed
- Tankerkoenig prices for requests with
stationIds
Is this also running for the Dutch petrol prices???
This is a great app. Good job well done
is there a way to add a favorite gas station
or make it a future project
I’m in the United States so I’m using that configuration -
@strawberry-3-141 Looks great!
@JerryP currently only Germany, Austria, USA and parts of Australia are covered by the module. If you find an API for fuel prices in the Netherlands I’m happy to integrate it. Please create an issue for the Github repository so it doesn’t get lost https://github.com/fewieden/MMM-Fuel/issues
@Ray currently it is only possible for Germany to select specific gas stations. The source for the USA doesn’t provide IDs that you can request for. Please create an issue for the Github repository so we can discuss some posibilities https://github.com/fewieden/MMM-Fuel/issues
Would the below API provide support for the UK and more in one?
https://developer.here.com/documentation/fuel-prices/dev_guide/topics/example-fuel-price.html
