    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 570.4k Views 48 Watching
    • F Offline
      FreddeHamm
      noob-question: how can i see the log?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @FreddeHamm
        @FreddeHamm in the terminal where you start the mirror or pm2 logs, and in the electron console(start the mirror with npm start dev)
        • F Offline
          FreddeHamm
          i found this
          ** Message: console message: http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js @117: SyntaxError: Unexpected token ‘(’. Expected a ‘:’ following the property name 'getTranslati$
          • F Offline
            FreddeHamm
            if i use npm start dev i get this…
            1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
            2 info using npm@5.5.1
            3 info using node@v8.3.0
            4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
            5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
            6 verbose cwd /home/pi
            7 verbose Linux 4.9.35+
            8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
            9 verbose node v8.3.0
            10 verbose npm v5.5.1
            11 error path /home/pi/package.json
            12 error code ENOENT
            13 error errno -2
            14 error syscall open
            15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
            16 error enoent This is related to npm not being able to find a file.
            17 verbose exit [ -2, true ]
            I did try to set up another mm … Same problem. only the fuel module doesnt show up. But if i use the browser on my pc it shows up…
            • Y Offline
              yawns Moderator @FreddeHamm
              @FreddeHamm
              Looks like you are not in the MagicMirror folder when running npm start dev
              Please try
              cd ~/MagicMirror
              npm start dev
                @FreddeHamm sounds like you are using midori browser or something similar which doesnt support es6 syntax
                  rrrene
                  Hi
                  great module!
                  I wanted to use my own header for your module to get the same look as the other moduled.
                  Unfortunately I don‘t understand how to disable the view of your implemented header.
                  At the moment I have two headers :)
                  Thanks.
                  Best regards
                    strawberry 3.141 Project Sponsor Module Developer @rrrene
                    @rrrene custom.css .MMM-Fuel header.align-left { display: none; }
                      DamienWakeford1
                      Hi guys I’m from South Africa, I have just started playing with the magic mirror today I have managed to the calendar weather and news for South Africa I would really like to add fuel prices and email notifications to it but don’t know how and can find any videos showing how to do it just that they did it if that makes sence
                      strawberry 3.141S D 2 Replies Last reply Reply Quote 0
                        strawberry 3.141 Project Sponsor Module Developer @DamienWakeford1
                        @DamienWakeford1 this module supports only germany and austria, not sure if it is possible to get the same information for your country via an api
                          doubleT Module Developer @DamienWakeford1
                          @DamienWakeford1
                          Do you have a favorite station or brand and do they have a website with live feed of the prices? If they have an API, maybe I have something, if it’s accessable.
                            rrrene @strawberry 3.141
                            @strawberry-3.141 said in MMM-Fuel:
                            Working perfect! Thank you m8.
                            Have a nice evening.
                            Best regards,
                            René
                            • X Offline
                              xray2607
                              Chaps,
                              Pethaps again a newbie question, but how do I configure this module for Austria, spritpreisrechner?
                              Anything ‘special’ to consider?
                              I do not get an error message for the config.js, but I also do not get a populated list for my Diesel.
                              Do I need to specify the provider, or does the module do the look up based on my location?
                              Any hint/help is greatly appreciated.
                              Many thanks,
                              XR
                                strawberry 3.141 Project Sponsor Module Developer @xray2607
                                @xray2607 you need to specify provider: 'spritpreisrechner', also spritpreisrechner changed the api, so you might want to use the develop branch git checkout develop
                                • K Offline
                                  killing joke
                                  Hey @ all,
                                  I think I have a small issue with the MMM-Fuel but I don´t know how to solve it. I installed the module as written in the manual but unfortunately it doesn´t show anything on the expected area (bottom_left)
                                  Below the snippet of the code within the config.js-file.
                                  			module: "MMM-Fuel",
                                  			postion: "bottom_left",
                                  				provider: "tankerkoenig",
                                  				api_key: "API-KEY",
                                  				lat: 52.9863800,
                                  				lng: 9.8433800,
                                  				types: ["diesel", "e5"],
                                  				sortby: "diesel",
                                  				radius: 10,
                                  				updateInterval: 900000,
                                  				max: 5
                                  Any ideas how I can fix it?
                                  Thanks in advance
                                    bjoern
                                    I’ve been using the module for a while, but since this morning I’m not getting any posts.
                                      @killing-joke you wrote postion instead of position
                                      @bjoern which provider (tankerkoenig or spritpreisrechner) just checked it and I’m getting results
                                        bjoern
                                        sorry, my mistake. I had no provider deposited. after I deposited Tankerkoenig everything works again now.
                                        • K Offline
                                          killing joke @strawberry 3.141
                                          @strawberry-3-141 said in MMM-Fuel:
                                          Thank you very much. I checked a lot of times the comma and the spaces and braces but didn´t checked the writing.
                                          It works fine. Cheers.
                                            I refactored the module and switched to nunjuck templates.
                                            I’m looking for people who are willing to test prices
                                            • tankerkoenig germany
                                            • spritpreisrechner austria
                                            how to test:
                                            • if not already done, clone the repository to your modules cd ~/MagicMirror/modules/ && git clone https://github.com/fewieden/MMM-Fuel.git
                                            • go to the module cd ~/MagicMirror/modules/MMM-Fuel
                                            • run git checkout develop
                                            • run npm i
                                            • test various config options
                                            [card:fewieden/MMM-Fuel]
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 5 / 9
