    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
    • K
      kiki99 @strawberry 3.141
      @strawberry-3.141 Oh my …, sorry for this stupid Mistake and the bad format.
      Many thanks for the quick help :)
      • F
        FreddeHamm
        @strawberry-3.141 I have some issues getting this thing fired up. I have a working api and found my location. But for some reason, the magic mirror won’t show the Fuel List.
          module: "MMM-Fuel",
          position: "bottom_right",
            api_key: 'Just My API',
            lat: 51.674177,
            lng: 6.460384,
            types: ["diesel"],
            sortBy: "diesel",
            radius: 10,
            colored: true,
            open: true,
            rotate: false
        Where is my mistake?!
        • strawberry 3.141S
          strawberry 3.141 Project Sponsor Module Developer @FreddeHamm
          @FreddeHamm you should remove the api key from your post, it’s kind of a password.
          I have to look on this on the weekend, can’t spot something obvious right now
          • F
            FreddeHamm
            any news?
            • strawberry 3.141S
              @FreddeHamm sorry, forgot about you. cant reproduce your issue though, i did a refresh install of mmm-fuel on my machine and inserted your config which resulted in the following state
              can you spot any errors in the logs (electron or terminal, pm2)? did you try to disable all other modules to reduce side effects?
              • F
                FreddeHamm
                Thanks for your help. If i open the magic mirror site via browser (my.rasperry.pi.ip:8080) i see the module. But its not shown on the screen of the mirror itself…
                • strawberry 3.141S
                  @FreddeHamm any errors?
                  • F
                    FreddeHamm
                    noob-question: how can i see the log?
                    • strawberry 3.141S
                      @FreddeHamm in the terminal where you start the mirror or pm2 logs, and in the electron console(start the mirror with npm start dev)
                      • F
                        FreddeHamm
                        i found this
                        ** Message: console message: http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js @117: SyntaxError: Unexpected token ‘(’. Expected a ‘:’ following the property name 'getTranslati$
                        • F
                          FreddeHamm
                          if i use npm start dev i get this…
                          1 verbose cli [ ‘/usr/local/bin/node’, ‘/usr/local/bin/npm’, ‘start’, ‘dev’ ]
                          2 info using npm@5.5.1
                          3 info using node@v8.3.0
                          4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                          5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
                          6 verbose cwd /home/pi
                          7 verbose Linux 4.9.35+
                          8 verbose argv “/usr/local/bin/node” “/usr/local/bin/npm” “start” “dev”
                          9 verbose node v8.3.0
                          10 verbose npm v5.5.1
                          11 error path /home/pi/package.json
                          12 error code ENOENT
                          13 error errno -2
                          14 error syscall open
                          15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                          16 error enoent This is related to npm not being able to find a file.
                          17 verbose exit [ -2, true ]
                          I did try to set up another mm … Same problem. only the fuel module doesnt show up. But if i use the browser on my pc it shows up…
                          • Y
                            yawns Moderator @FreddeHamm
                            @FreddeHamm
                            Looks like you are not in the MagicMirror folder when running npm start dev
                            Please try
                            npm start dev
                            • strawberry 3.141S
                              @FreddeHamm sounds like you are using midori browser or something similar which doesnt support es6 syntax
                                rrrene
                                Hi
                                great module!
                                I wanted to use my own header for your module to get the same look as the other moduled.
                                Unfortunately I don‘t understand how to disable the view of your implemented header.
                                At the moment I have two headers :)
                                Thanks.
                                Best regards
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @rrrene
                                  @rrrene custom.css .MMM-Fuel header.align-left { display: none; }
                                    DamienWakeford1
                                    Hi guys I’m from South Africa, I have just started playing with the magic mirror today I have managed to the calendar weather and news for South Africa I would really like to add fuel prices and email notifications to it but don’t know how and can find any videos showing how to do it just that they did it if that makes sence
                                    strawberry 3.141S D 2 Replies Last reply Reply Quote 0
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @DamienWakeford1
                                      @DamienWakeford1 this module supports only germany and austria, not sure if it is possible to get the same information for your country via an api
                                        doubleT Module Developer @DamienWakeford1
                                        @DamienWakeford1
                                        Do you have a favorite station or brand and do they have a website with live feed of the prices? If they have an API, maybe I have something, if it’s accessable.
                                          rrrene @strawberry 3.141
                                          @strawberry-3.141 said in MMM-Fuel:
                                          Working perfect! Thank you m8.
                                          Have a nice evening.
                                          Best regards,
                                          René
                                          • X
                                            xray2607
                                            Chaps,
                                            Pethaps again a newbie question, but how do I configure this module for Austria, spritpreisrechner?
                                            Anything ‘special’ to consider?
                                            I do not get an error message for the config.js, but I also do not get a populated list for my Diesel.
                                            Do I need to specify the provider, or does the module do the look up based on my location?
                                            Any hint/help is greatly appreciated.
                                            Many thanks,
                                            XR
                                            • 5 / 9
