    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 576.4k Views 48 Watching
      rakostamas
      Hey, I have just installed the module, but I realized one minor mistake. The distances in the table have too much numbers after the decimal point. Where can I change it to just one decimal number?
      • O Offline
        othomys
        Hello,
        I use the tankerkoenig-api to let me see the German fuel prices. Unfortunately, the special characters (ä, ö, ü, ß, …) are not displayed correctly. At which point can I adapt the encoding?
        Thank you in advance.
          dazza120
          Is there anyway to to get this for UK fuel prices?
          • strawberry 3.141S Offline
            @rakostamas I try to adjust it in the next update.
            @othomys I think that’s a problem with the nunjuck templates that I didn’T figure out yet.
            @dazza120 is there a public api for it?
            D R 2 Replies Last reply Reply Quote 0
              dazza120 @strawberry 3.141
              @strawberry-3-141 doesn’t look like the UK does have an api for fuel prices
                rakostamas @strawberry 3.141
                @strawberry-3-141
                I reinstalled the mirror and installed the module again, however it stopped working. (It’s shows only “loading”) I’m using the same config file as before. Every module beside this working :/ Is it possible, that there is a bug in the module?
                  strawberry 3.141 Project Sponsor Module Developer @rakostamas
                  @rakostamas which branch are you using? Develop or master? On develop I’m working on a refactoring, so bugs are definetly possible. Master was probably not changed in a year.
                  Any errors in the console?
                  Did you install the dependencies?
                  Can you post your confit part without the API key and a bit modified gps position?
                    @strawberry-3-141
                    here is my config:
                    			module: "MMM-Fuel",
                    				provider: "spritpreisrechner",
                    				lat: 47.041194,
                    				lng: 15.453377,
                    				types: ["e5", "diesel"],
                    				radius: 6,
                    				max: 4,
                    				sortBy: "e5",
                    				open: true,
                    The mirror only displays the header and loading…
                    I have installed it in the following way:
                      sdetweil @rakostamas
                      @rakostamas run
                      npm start dev
                      to open the development screen, select the console tab… are there any errors (in red) shown?
                        rakostamas @sdetweil
                        Yes it seems :D
                          sdetweil
                          wrong folder… in MagicMirror always for start. not module folder
                            1 verbose cli [ '/usr/bin/node', '/usr/bin/npm', 'start', 'dev' ]
                            2 info using npm@6.6.0
                            3 info using node@v9.11.2
                            4 verbose stack Error: missing script: start
                            4 verbose stack     at run (/usr/lib/node_modules/npm/lib/run-script.js:155:19)
                            4 verbose stack     at /usr/lib/node_modules/npm/lib/run-script.js:63:5
                            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:115:5
                            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:418:5
                            4 verbose stack     at checkBinReferences_ (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:373:45)
                            4 verbose stack     at final (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:416:3)
                            4 verbose stack     at then (/usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:160:5)
                            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/read-package-json/read-json.js:364:12
                            4 verbose stack     at /usr/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:90:16
                            4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:525:3)
                            5 verbose cwd /home/pi/MagicMirror/modules/MMM-Fuel
                            6 verbose Linux 4.14.79-v7+
                            7 verbose argv "/usr/bin/node" "/usr/bin/npm" "start" "dev"
                            8 verbose node v9.11.2
                            9 verbose npm  v6.6.0
                            10 error missing script: start
                            11 verbose exit [ 1, true ]
                            S strawberry 3.141S 2 Replies Last reply Reply Quote 0
                              @rakostamas said in MMM-Fuel:
                              please do
                              cd ~/MagicMirror
                              then
                              npm start dev
                                rakostamas
                                Yes I got errors.
                                GET http://localhost:8080/modules/MMM-Fuel//MMM-Fuel.js net : : ERR_CACHE_READ_FAILURE
                                Error on loading script: modules/MMM-Fuel//MMM-Fuel.js
                                  sdetweil
                                  sorry, I do not know why reading from the local disk would fail with cache read failure error
                                    @rakostamas as @sdetweil already mentioned you need to start the mirror not the module.
                                    cd ~/MagicMirror && npm start dev
                                      @strawberry-3-141
                                      yes, I have opened it, and I got the errors what I wrote in my last comment
                                        @rakostamas did you check that the file exists? Maybe something went wrong during the cloning of the module
                                        • V Offline
                                          VanDerPol
                                          hello
                                          I have the same problem like rakostamas.
                                          As headline there stands Spritpreise und below there stands loading.
                                          I am from Austria and I use provider Spritpreisrechner.
                                          Unfortunately I can’t find the mistake. Could you please help me?
                                          Sorry My english is not the yellow from the egg :)
                                          My Config:
                                                               module: "MMM-Fuel",
        lat: 48.527710,
        lng: 16.361530,
        radius: 15,
        max: 5,
        map_api_key: false,
        zoom: 12,
        width: 600,
        height: 600,
        colored: true,
        open: false,
        shortenText: false,
        showAddress: true,
        showOpenOnly: false,
        iconHeader: true,
        rotate: true,
        types: ['diesel'],
        sortBy: 'diesel',
        rotateInterval: 60 * 1000, // every minute
        updateInterval: 15 * 60 * 1000, // every 15 minutes
        provider: 'spritpreisrechner',
        toFixed: false
                                            I just merged a new version of this module into master.
                                            New: Support for gas stations in new south wales australia
                                            Changed: I rewrote most of the module, make sure you also install the dependencies after the update.
                                            [card:fewieden/MMM-Fuel]
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 6 / 9
