    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 570.4k Views 48 Watching
      Daugenix
      Can I only show 3 specific gas stations?
      The gas stations that are displayed to me, I never go there
        Daugenix @Daugenix
        @Daugenix said in MMM-Fuel:
        Statement:
        max: 3
        is not what I mean.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @Daugenix
          @Daugenix this is currently not implemented as most providers give not many results back
            Version 2.0.1
            Fixed: Ellipsis rendering in nunjuck template with config option shortenText active
            [card:fewieden/MMM-Fuel]
              db1mso
              This post is deleted!
                anno1972
                Hi all
                tankerkoenig does not provide API keys anomore - as far as I see there is no free provider anymore.
                How will this module run in future?
                Cheers
                Andy
                FoziF cowboysdudeC 2 Replies Last reply Reply Quote 0
                • FoziF Offline
                  Fozi Project Sponsor @anno1972
                  @anno1972 you can still register for a API key
                  https://creativecommons.tankerkoenig.de/ —> API-key
                    anno1972 @Fozi
                    @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
                    Happy New Year
                    • cowboysdudeC Offline
                      cowboysdude Module Developer @anno1972
                      @anno1972 NO api, no work.
                      It can be done … I did it for the US but no clue about outside the country…
                        Stefan_TR96
                        Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
                        npm start dev
                        puts out the error
                        TypeError: collection[type] is not iterable
                        at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
                        at process._tickCallback (internal/process/next_tick.js:68:7)
                        Anybody an idea what I can do to solve this problem?
                        Thanks S
                        cowboysdudeC S 2 Replies Last reply Reply Quote 0
                          cowboysdude Module Developer @Stefan_TR96
                          @Stefan_TR96 Data could have changed.
                            sdetweil @Stefan_TR96
                            @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
                              Stefan_TR96 @sdetweil
                              @sdetweil said in MMM-Fuel:
                              tried to install it again and got following warning:
                              npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
                                @Stefan_TR96 that’s just a warning
                                  Stefan_TR96
                                  @cowboysdude if I type the generated url manually to the browser, I get the data
                                    @Stefan_TR96 >tried to install it again and got following warning:
                                    what is ‘it’…
                                    the module may need updating after MM was updated…
                                    do
                                    cd ~/MagicMirror/modules/MMM-Fuel
                                    npm install
                                      Stefan_TR96
                                      @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                                        @Stefan_TR96 said in MMM-Fuel:
                                        sudo
                                        never sudo
                                          Stefan_TR96
                                          @sdetweil same results without sudo
                                            @Stefan_TR96 yes, does mm run? Do you get output?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 7 / 9
