    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @rakostamas
      @rakostamas did you check that the file exists? Maybe something went wrong during the cloning of the module
      • V
        VanDerPol
        hello
        I have the same problem like rakostamas.
        As headline there stands Spritpreise und below there stands loading.
        I am from Austria and I use provider Spritpreisrechner.
        Unfortunately I can’t find the mistake. Could you please help me?
        Sorry My english is not the yellow from the egg :)
        My Config:
                             module: "MMM-Fuel",
                                     lat: 48.527710,
                                     lng: 16.361530,
                                     radius: 15,
                                     max: 5,
                                     map_api_key: false,
                                     zoom: 12,
                                     width: 600,
                                     height: 600,
                                     colored: true,
                                     open: false,
                                     shortenText: false,
                                     showAddress: true,
                                     showOpenOnly: false,
                                     iconHeader: true,
                                     rotate: true,
                                     types: ['diesel'],
                                     sortBy: 'diesel',
                                     rotateInterval: 60 * 1000, // every minute
                                     updateInterval: 15 * 60 * 1000, // every 15 minutes
                                     provider: 'spritpreisrechner',
                                     toFixed: false
        • strawberry 3.141S
          I just merged a new version of this module into master.
          New: Support for gas stations in new south wales australia
          Changed: I rewrote most of the module, make sure you also install the dependencies after the update.
          [card:fewieden/MMM-Fuel]
            Daugenix
            Can I only show 3 specific gas stations?
            The gas stations that are displayed to me, I never go there
              Daugenix @Daugenix
              @Daugenix said in MMM-Fuel:
              Statement:
              max: 3
              is not what I mean.
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @Daugenix
                @Daugenix this is currently not implemented as most providers give not many results back
                • strawberry 3.141S
                  Version 2.0.1
                  Fixed: Ellipsis rendering in nunjuck template with config option shortenText active
                    db1mso
                    • A
                      anno1972
                      Hi all
                      tankerkoenig does not provide API keys anomore - as far as I see there is no free provider anymore.
                      How will this module run in future?
                      Cheers
                      Andy
                      FoziF cowboysdudeC 2 Replies Last reply Reply Quote 0
                      • FoziF
                        Fozi Project Sponsor @anno1972
                        @anno1972 you can still register for a API key
                        https://creativecommons.tankerkoenig.de/ —> API-key
                        • A
                          anno1972 @Fozi
                          @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
                          Happy New Year
                          • cowboysdudeC
                            cowboysdude Module Developer @anno1972
                            @anno1972 NO api, no work.
                            It can be done … I did it for the US but no clue about outside the country…
                              Stefan_TR96
                              Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
                              npm start dev
                              puts out the error
                              TypeError: collection[type] is not iterable
                              at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
                              at process._tickCallback (internal/process/next_tick.js:68:7)
                              Anybody an idea what I can do to solve this problem?
                              Thanks S
                              cowboysdudeC S 2 Replies Last reply Reply Quote 0
                              • cowboysdudeC
                                cowboysdude Module Developer @Stefan_TR96
                                @Stefan_TR96 Data could have changed.
                                  sdetweil @Stefan_TR96
                                  @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
                                    Stefan_TR96 @sdetweil
                                    @sdetweil said in MMM-Fuel:
                                    tried to install it again and got following warning:
                                    npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
                                      @Stefan_TR96 that’s just a warning
                                        Stefan_TR96
                                        @cowboysdude if I type the generated url manually to the browser, I get the data
                                          @Stefan_TR96 >tried to install it again and got following warning:
                                          what is ‘it’…
                                          the module may need updating after MM was updated…
                                          do
                                          cd ~/MagicMirror/modules/MMM-Fuel
                                          npm install
                                            Stefan_TR96
                                            @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                                            • 7 / 9
