    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 586.1k Views 48 Watching
    • strawberry 3.141S
      Version 2.0.1
      Fixed: Ellipsis rendering in nunjuck template with config option shortenText active
      [card:fewieden/MMM-Fuel]
        db1mso
        • A
          anno1972
          Hi all
          tankerkoenig does not provide API keys anomore - as far as I see there is no free provider anymore.
          How will this module run in future?
          Cheers
          Andy
          FoziF cowboysdudeC 2 Replies Last reply Reply Quote 0
          • FoziF
            Fozi Project Sponsor @anno1972
            @anno1972 you can still register for a API key
            https://creativecommons.tankerkoenig.de/ —> API-key
            • A
              anno1972 @Fozi
              @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
              Happy New Year
              • cowboysdudeC
                cowboysdude Module Developer @anno1972
                @anno1972 NO api, no work.
                It can be done … I did it for the US but no clue about outside the country…
                  Stefan_TR96
                  Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
                  npm start dev
                  puts out the error
                  TypeError: collection[type] is not iterable
                  at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
                  at process._tickCallback (internal/process/next_tick.js:68:7)
                  Anybody an idea what I can do to solve this problem?
                  Thanks S
                  cowboysdudeC S 2 Replies Last reply Reply Quote 0
                  • cowboysdudeC
                    cowboysdude Module Developer @Stefan_TR96
                    @Stefan_TR96 Data could have changed.
                      sdetweil @Stefan_TR96
                      @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
                        Stefan_TR96 @sdetweil
                        @sdetweil said in MMM-Fuel:
                        tried to install it again and got following warning:
                        npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
                          @Stefan_TR96 that’s just a warning
                            Stefan_TR96
                            @cowboysdude if I type the generated url manually to the browser, I get the data
                              @Stefan_TR96 >tried to install it again and got following warning:
                              what is ‘it’…
                              the module may need updating after MM was updated…
                              do
                              cd ~/MagicMirror/modules/MMM-Fuel
                              npm install
                                Stefan_TR96
                                @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                                  @Stefan_TR96 said in MMM-Fuel:
                                  sudo
                                  never sudo
                                    Stefan_TR96
                                    @sdetweil same results without sudo
                                      @Stefan_TR96 yes, does mm run? Do you get output?
                                        Stefan_TR96
                                        @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                                          @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                                          You can filter by module, by placing part of the module name in the filter field.
                                            Stefan_TR96
                                            is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
                                            • 7 / 9
