    MMM-Fuel
    fuel pricegas stationpetrol stationvoice-controltankerkoenigspritpreisrechnernsw
    178 Posts 48 Posters 589.6k Views 48 Watching
    • FoziF
      Fozi Project Sponsor @anno1972
      @anno1972 you can still register for a API key
      https://creativecommons.tankerkoenig.de/ —> API-key
      A 1 Reply Last reply
      • A
        anno1972 @Fozi
        @Fozi thanks - by fault I used the wrong link to the Tankerkönig Monitor where registration wasn’t possible
        Happy New Year
        • cowboysdudeC
          cowboysdude Module Developer @anno1972
          @anno1972 NO api, no work.
          It can be done … I did it for the US but no clue about outside the country…
            Stefan_TR96
            Hi, since I updated MagicMirror I have a Problem running MMM-Fuel. I’m using the Provider “Spritpreisrechner” and it’s only “Loading”.
            npm start dev
            puts out the error
            TypeError: collection[type] is not iterable
            at Object.getData (/home/pi/MagicMirror/modules/MMM-Fuel/apis/spritpreisrechner.js:141:41)
            at process._tickCallback (internal/process/next_tick.js:68:7)
            Anybody an idea what I can do to solve this problem?
            Thanks S
            cowboysdudeC S 2 Replies Last reply
            • cowboysdudeC
              cowboysdude Module Developer @Stefan_TR96
              @Stefan_TR96 Data could have changed.
                sdetweil @Stefan_TR96
                @Stefan_TR96 did u run npm install in the module folders with a package.json file? u need to
                  Stefan_TR96 @sdetweil
                  @sdetweil said in MMM-Fuel:
                  tried to install it again and got following warning:
                  npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none is installed. You must install peer dependencies yourself.
                    @Stefan_TR96 that’s just a warning
                      Stefan_TR96
                      @cowboysdude if I type the generated url manually to the browser, I get the data
                        @Stefan_TR96 >tried to install it again and got following warning:
                        what is ‘it’…
                        the module may need updating after MM was updated…
                        do
                        cd ~/MagicMirror/modules/MMM-Fuel
                        npm install
                          Stefan_TR96
                          @sdetweil i did de install again (changed to MM-Fuel directory and did sudo npm install) as you wrote and got the warning i posted
                            @Stefan_TR96 said in MMM-Fuel:
                            sudo
                            never sudo
                              Stefan_TR96
                              @sdetweil same results without sudo
                                @Stefan_TR96 yes, does mm run? Do you get output?
                                  Stefan_TR96
                                  @sdetweil yes, mirror and all other modules are running without any errors … just mmm-fuel is displaying loading
                                    @Stefan_TR96 open the developers window, ctrl-shift-i on the keyboard, select the console tab and scroll up to see any errors.
                                    You can filter by module, by placing part of the module name in the filter field.
                                      Stefan_TR96
                                      is there any possibility to control this without a physical keybord? I’m just able to connect via Remote desktop or ssh? Thx for your help, I’m a complete beginner
                                      • strawberry 3.141S
                                        I just released version 2.0.2
                                        Added
                                        • French Translations
                                        • Clarification for config option updateInterval in readme
                                        Changed
                                        • Dependency Update
                                        Removed
                                        • Github pages
                                        https://github.com/fewieden/MMM-fuel
                                        [card:fewieden/MMM-Fuel]
                                        C 1 Reply Last reply
                                          Cetax @strawberry 3.141
                                          @strawberry-3-141 Hi,
                                          is there a way to hide the distance?
                                          Can you tell me where I can comment that out?
                                          Thank you for your help.
                                          greeting
                                          Stefan
                                          • strawberry 3.141S
                                            strawberry 3.141 Project Sponsor Module Developer @Cetax
                                            @Cetax add this in your custom.css file at ~/MagicMirror/css/custom.css
                                            .MMM-Fuel th:nth-child(3), .MMM-Fuel td:nth-child(3) {
                                                display: none;
                                            • 7 / 9
